- Způsob instalaceHome Assistant OS
- Core2025.11.3
- Supervisor2025.11.4
- Operating System16.3
- Frontend20251105.1
I have connected USB HDD unable mount it to HA, as I can not see it in System - Storage. What command should I use in linux?
It’s not recommended.
When you map the new drive to somewhere Ha can find it, it ends up in the path of the backup. If the mounted drive has too much data, when you back-up HA will run out of disk space on the main drive and crash.
Thanks, My intention was to use HDD as NAS. So it seems to be better to use separate RBi.
