HDL Buspro Integration for Home Assistant
A custom integration to control and monitor HDL Buspro devices locally in Home Assistant.
Links
- Repository
- Documentation (Available of many languages)
- Device setup examples (UI + YAML):
- YAML modes reference
Supported Home Assistant entities/features
- Domains:
light,switch,cover,climate,fan,sensor,binary_sensor,event - Gateway/device management: add/edit/remove devices from config flow, per-model channel handling
- Panels/events: per-button
evententities, action decoding, last-action sensor - Scenes & commands (services):
buspro.activate_scenebuspro.set_universal_switchbuspro.send_message
- Optional command confirmation for reliable state sync:
enable_confirmationconfirmation_timeoutconfirmation_retries
- Diagnostics support:
- Logic controller connectivity/firmware/last-seen
- Dimmer diagnostics (min/max brightness/load-type where available)
- YAML compatibility: legacy entity-centric + modern device-centric YAML modes
Supported device models
Infrastructure / controller
HDL-MBUS01IP.431(gateway metadata)HDL-MCLog.431(logic controller diagnostics/events)
Relay modules
HDL-MR0410.431,HDL-MR0810.432,HDL-MR1210.433,HDL-MR1610.433HDL-MR0416.431,HDL-MR0416C.431,HDL-MR0416D.431HDL-MR0816.432,HDL-MR0816C.232,HDL-MR0816D.432HDL-MR1216.433,HDL-MR1216D.433,HDL-MR1616.434HDL-MR0420C.431,HDL-MR0820C.432,HDL-MR1220C.433
Dimmers / ballast / DALI
HDL-MD0206.432,HDL-MD0403.432,HDL-MD0602.432HDL-MDT0203.433,HDL-MDT0203.532HDL-MDT04015.433,HDL-MDT04015.532HDL-MDT06015.433,HDL-MDT06015.533HDL-MDLED0605.432HDL-MRDA0610.432,HDL-MRDA0610.433SB-DN-DALI64
Dry-contact / multisensor
HDL-MS04.432,HDL-MS24.232HDL-MSP02.4C,HDL-MSP07M.4C,HDL-MS08M.4C,HDL-MS12M.4C
Panels
HDL-MPTL3C.48,HDL-MPTL4C.48,HDL-MPTL4.460HDL-MP4S/TILE.48,HDL-MP2B/TILE.48,HDL-MP4B-A/TILE.48,HDL-MP4B/TILE.48HDL-MP2B.480,HDL-MP4B.480,HDL-MPL8.431,HDL-M/PT4.1- Generic panel profile:
HDL panel
Climate / floor heating
HDL-MFH04.432,HDL-MFH06.432HDL-M/HVAC8.1,HDL-MPED4.431- Generic AC profile:
HDL Buspro AC Controller
Cover / fan / universal-switch outputs
HDL-MW02.431,HDL-MWM45.431- Generic profiles:
HDL Buspro Curtain ControllerHDL Buspro Variable-speed Fan OutputHDL Buspro On/Off Fan OutputHDL Buspro Universal Switch
Notes on model support
Some models are handled via family mapping/generic compatibility where vendor-specific extended behaviors are not yet exposed as dedicated entities. Core control and state handling are supported.
What feedback is most useful
- Model + firmware combinations not listed above
- Reproducible timing/reliability issues (especially on noisy networks)
- Panel action decoding edge cases
- Any mismatch between physical and HA state traces
If you want to test, reply with your gateway model, Buspro model list, and HA version — I can provide a recommended migration/setup path.
