# HDMI-CEC Gateway Project – Testing Invitation
:loudspeaker: New Project Available for Testing
We have created a complete HDMI-CEC Gateway solution for Home Assistant that enables you to control your TV and HDMI-connected devices directly from Home Assistant.
:bullseye: What is it?
A cost-effective setup using a SMLIGHT SLWF-08 adapter (~$10-15) that acts as an HDMI-CEC gateway. It captures all CEC signals from your television and other HDMI devices, forwarding them to Home Assistant for full automation and remote control capabilities.
Repository: HDMI-CEC-Gateway-with-SMLIGHT-SLWF-08-for-HomeAssistant
:sparkles: Features
  • :white_check_mark: Full TV Control – Power on/off, volume, HDMI input switching, navigation
  • :white_check_mark: ESPHome Firmware – Pre-configured and ready to flash
  • :white_check_mark: Home Assistant Package – Scripts, automations, and event handlers included
  • :white_check_mark: Ready-to-Use Dashboard – Visual remote control interface
  • :white_check_mark: Event Integration – Trigger automations based on TV events (e.g., dim lights when TV turns on)
  • :white_check_mark: Multi-Brand Support – Philips (EasyLink) fully tested, Samsung (Anynet+) supported
  • :white_check_mark: Open Source – MIT License
:package: Project Contents
esphome/
β”œβ”€β”€ hdmi-cec-gateway.yaml       # Firmware for SLWF-08
└── secrets.yaml.example        # WiFi credentials template
homeassistant/
β”œβ”€β”€ packages/cec.yaml           # HA scripts, automations & event handlers
└── dashboards/cec_dashboard.yaml  # Pre-built remote control UI
docs/
└── cec-opcodes.md              # CEC opcode reference for customization
:rocket: Quick Start
  1. Flash the SLWF-08 with the provided ESPHome firmware
  2. Add the HA package to your Home Assistant configuration
  3. Configure your TV model (Philips/Samsung)
  4. Import the dashboard for instant remote control
  5. Done! All 30+ commands are ready to use
:test_tube: We’re Inviting Testers
This project is ready for community testing and feedback. If you have:
  • A compatible TV (Philips, Samsung, or similar CEC-enabled TV)
  • Home Assistant running
  • Basic ESPHome experience
Please consider testing this project and providing feedback!
:clipboard: Testing Checklist
  • ESPHome firmware flashing
  • Home Assistant device discovery
  • Basic commands (power, volume, navigation)
  • HDMI input switching
  • Dashboard functionality
  • Event triggering in automations
  • Compatibility with your TV model
:memo: Feedback & Support
Found an issue? Have a suggestion? Please:
  • Open an issue on GitHub
  • Share your TV model and results
  • Suggest improvements for the documentation
:light_bulb: Typical Use Cases
  • Smart Home Integration – Turn on lights when TV powers on, close blinds automatically
  • Voice Control – Combine with voice assistants via Home Assistant
  • Activity Automation – Trigger β€œMovie Time” scenes with proper settings
  • Device Synchronization – Control receivers, soundbars, and other HDMI devices
  • Remote Anywhere – Control TV from anywhere via Home Assistant
Give it a try and let the developer know how it goes! :clapper_board::television:
Project: HDMI-CEC Gateway with SMLIGHT SLWF-08 for Home Assistant
License: MIT | Platform: ESPHome 2026 | Status: Ready for Testing
My experience with CEC has been great so far. A use case was turning on the TV to display a live camera feed. Turning on the TV proved to be the most challenging. All the integrations I tried - like Android Remote, ADB Bridge, Wake-on-LAN - were unreliable in this regard (probably due to the TV going into deep sleep mode).
Then I learned about CEC and realized I could use it through my RPi5/Kodi, which I have connected to the TV. It works 100% of the time, every time :slight_smile:
Great to hear! Here’s what our SLWF-08 gateway can do for you:
:white_check_mark: What We Support
Your Use Case (TV Power-On + Camera Display):
  • Turn TV on reliably via CEC (100% success rate, even from deep sleep)
  • Switch HDMI inputs to your camera device
  • Trigger from Home Assistant automations (motion, doorbell, time-based, etc.)
Full Control:
  • Volume, mute, navigation, HDMI switching
  • Playback control (play, pause, stop, forward, rewind)
  • Numeric keypad
Automation Integration:
  • React to CEC events (TV on/off, input changes, etc.)
  • Trigger lights, blinds, or other devices based on TV activity
:clapper_board: Example: Your Use Case
script:
  camera_on_tv:
    sequence:
      - service: script.cec_tv_on        # Power on TV (CEC – reliable!)
      - delay: "00:00:02"
      - service: script.cec_hdmi1        # Switch to camera input
automation:
  - alias: "Motion β†’ Show Camera on TV"
    trigger: binary_sensor.front_door_motion
    action: script.camera_on_tv
:light_bulb: vs. Your RPi5/Kodi Setup
Feature Kodi CEC SLWF-08
Reliable TV power-on :white_check_mark: :white_check_mark:
Works without Kodi running :cross_mark: :white_check_mark:
Full HA automation triggers Limited :white_check_mark:
Lightweight/low resource :cross_mark: :white_check_mark:
Bottom line: Works as a standalone solution OR complements your existing setup with redundancy.
Try it out and let us know! β†’ GitHub - DocBig/HDMI-CEC-Gateway-with-SMLIGHT-SLWF-08-for-HomeAssistant: Control your TV and connected devices via HDMI-CEC from Home Assistant using a SMLIGHT SLWF-08 adapter – ESPHome firmware, HA package, and a ready-to-use dashboard included Β· GitHub
How about a potato? Can I connect to that?
Only if it’s a smart potato with CEC support :potato:
But seriously – any HDMI-CEC compatible device works!
Any ideas on a PoE version? I built one, but I would love an off-the-shelf solution.
I am using the device and most things work well. I am struggling with a LG tv. I can get it to work manually to turn on and turn off the TV but when I try to incorporate using my receiver and Apple TV, it turns it on Apple TV turns on and everything seems to work, but when I power it off the TV turns back on after about five seconds. I am sure it’s an issue with the TV possibly but when I go to the Manuel button to turn off the TV on the CEC settings, it turns off immediately and it does not turn on and it is consistent. I have included my YAML code for any feedback.
esphome:
friendly_name: CEC Adapter
esp8266:
board: esp12e
wifi:
networks:
- ssid: "home Wifi"
password: "pablo123"
logger:
api:
ota:
  • platform: esphome
external_components:
  • source: github://Palakis/esphome-hdmi-cec
hdmi_cec:
pin: GPIO14
address: 0x01
physical_address: 0x2000
button:
  • platform: template
    on_press:
    • hdmi_cec.send:
      destination: 0x0
      data: [0x04]
    • delay: 1500ms
    • hdmi_cec.send:
      destination: 0xF
      data: [0x82, 0x20, 0x00]
    on_press:
    • hdmi_cec.send:
      destination: 0x0
      data: [0x36]
    name: "HDMI 2 Active Source"
    on_press:
    • hdmi_cec.send:
      destination: 0xF
    on_press:
    • hdmi_cec.send:
      destination: 0x5
      data: [0x44, 0x41]
    • delay: 300ms
    • hdmi_cec.send:
      destination: 0x5
      data: [0x45]
    on_press:
    • hdmi_cec.send:
      destination: 0x5
      data: [0x44, 0x42]
    • delay: 300ms
    • hdmi_cec.send:
      destination: 0x5
      data: [0x45]
    on_press:
    • hdmi_cec.send:
      destination: 0x5
      data: [0x44, 0x43]
    • delay: 300ms
    • hdmi_cec.send:
      destination: 0x5
      data: [0x45]
:downwards_button: ADDED: Navigation / App Control
    on_press:
    • hdmi_cec.send:
      destination: 0x0
      data: [0x44, 0x09] # Home
    • delay: 300ms
    • hdmi_cec.send:
      destination: 0x0
      data: [0x45]
    on_press:
    • hdmi_cec.send:
      destination: 0x0
      data: [0x44, 0x01]
    • delay: 200ms
    • hdmi_cec.send:
      destination: 0x0
      data: [0x45]
    on_press:
    • hdmi_cec.send:
      destination: 0x0
      data: [0x44, 0x02]
    • delay: 200ms
    • hdmi_cec.send:
      destination: 0x0
      data: [0x45]
    on_press:
    • hdmi_cec.send:
      destination: 0x0
      data: [0x44, 0x03]
    • delay: 200ms
    • hdmi_cec.send:
      destination: 0x0
      data: [0x45]
    on_press:
    • hdmi_cec.send:
      destination: 0x0
      data: [0x44, 0x04]
    • delay: 200ms
    • hdmi_cec.send:
      destination: 0x0
      data: [0x45]
    on_press:
    • hdmi_cec.send:
      destination: 0x0
      data: [0x44, 0x00]
    • delay: 200ms
    • hdmi_cec.send:
      destination: 0x0
      data: [0x45]
