I recently got started with HA. I have successfully installed HA on PI 5 and everything worked perfectly. I then installed on HA Yellow (with CM5) and the server works great from client access. My issue is that no matter what I try I cannot get the CLI output from the Yellow HDMI port to display on an attached HDMI display. I have tried multiple cable combinations, multiple monitors and power off reset multiple times with no success.
Is there something I am missing with jumper settings (jumper was returned to UART after install) or some other config step?
