Heat pump control via INVERBOOST app/AlsavoPro integration
I’ve set up this integration and managed to compile: GitHub - gllmlbrt/Alsavo-HassOS: Usage of strandborg/AlsavoCtrl to integrate the Alsavo (Swin&Fun water heatpumps) further into home assistant via command and MQTT publishing and integration of HVAC entity
As I have not been able to connect my heat pump to the AlsavoPro app, I am using the INVERBOOST app instead. However I am not able to connect to neither the internal or external IP of the heat pump, it’s just throwing ‘server is not responding’ Am I trying something that’s impossible?
Same here.
I can connect my Inverboost 095p to the Inverboost app over 2.4GHz Wifi. I have tried also to connect with the AlsavoPro app, but this does not seem to work, the device is never found.
Any ideas?
