Heating automation is driving me crazy
Hello!
I’m trying to create a heating automation with TS0601_thermostat and ZG-001. I’ve added them into my HAG, using a SONOFF ZigBee 3.0 Dongle Plus.
What I want to achieve is to create an automation that turns on the boiler when a thermostat is in heating mode.
There are no results yet and winter is coming :).
I’m new on this field and I really need help.
Would the Generic Thermostat integration be any help?
Jack, thank you for your response, but the generic thermostat expects a ‘Temperature sensor’. In my configuration there is no such thing.
Anyway, I managed to create the automation I needed. I’ll leave the YAML here, maybe someone will need it:
alias: Heat all rooms (hvac action)
description: ""
triggers:
  - trigger: state
    entity_id:
      - climate.closet
      - climate.kitchen
      - climate.hallway
      - climate.big_bedroom
      - climate.bedroom
      - climate.bathroom_floor
    attribute: hvac_action
  - trigger: homeassistant
    event: start
  - trigger: event
    event_type: automation_reloaded
actions:
  - variables:
      thermostats:
        - climate.closet
        - climate.kitchen
        - climate.hallway
        - climate.bedroom
      hvacs: |-
          thermostats
          | map('state_attr','hvac_action')
          | map('string')
          | map('lower')
          | list
      any_heating: "{{ 'heating' in hvacs }}"
  - if:
      - condition: template
        value_template: "{{ any_heating }}"
    then:
      - action: switch.turn_on
          entity_id: switch.centrala
    else:
      - action: switch.turn_off
initial_state: true
mode: restart
