Heating Decision Engine — A centralized heating control architecture for Home Assistant
Many Home Assistant heating setups end up with multiple automations competing with each other:
- presence automations
- window detection
- vacation mode
- manual overrides
- weather anticipation
- stove interaction
- anti-freeze protection
Over time this becomes difficult to reason about.
Automations start to conflict and it becomes harder to understand why the heating changed state.
To solve this I built a small architecture pattern that centralizes all heating decisions into a single decision engine.
Instead of many automations directly controlling the heating system, the system works like this:
context signals → trigger automation → decision engine → execution scripts
Core idea
The decision engine evaluates the current context and decides between three possible outcomes:
comfortreducedneutre(explicit abstention)
The neutre state is important: it means
the system evaluated the context and intentionally decided to do nothing.
This prevents unnecessary service calls and oscillations.
Architecture
Context signals
(presence, windows, house mode, vacation…)
Automation Trigger
(single authority)
Apply Comfort Apply Reduced
(execution) (execution)
└───────► Heating System
(API / climate entity)
Key principles
The project follows a few architectural rules:
Single decision authority
Only the decision engine decides if heating should change.
Decision ≠ execution
The engine decides.
Separate scripts apply the change.
Explicit abstention
neutre means:
Heating is already correct or no action is needed.
Strict priority hierarchy
The first matching rule always wins.
Anti-bounce protection
Optional timers prevent rapid oscillations or API spam.
Features
- centralized heating decision logic
- strict priority hierarchy
- explicit abstention (
neutre) - anti-bounce protection
- prevention of redundant service calls
- optional observability helpers
- full YAML implementation (no custom integration)
Project structure
The repository contains:
scripts/
heating_decision_engine.yaml
heating_apply_comfort.yaml
heating_apply_reduced.yaml
automations/
automation_trigger.yaml
sensors/
heating_thermal_target.yaml
helpers/
helpers.yaml
packages/
heating_decision_engine_example.yaml
docs/
architecture.md
decision_engine.md
apply_scripts.md
thermal_target_sensor.md
An example Home Assistant package is included to quickly test the system.
GitHub repository
Full project, documentation and examples:
https://github.com/antoinevalentinHA/ha-heating-decision-engine
Feedback welcome
I’m sharing this mainly as an architecture pattern for heating control in Home Assistant.
I’m curious to see:
- how others structure their heating automations
- whether this pattern could be useful for other setups
- possible improvements to the decision logic.
Feedback and ideas are welcome.
