Hi HAers,
I have a problem! I have a dumb heating system i want to leave in place.
I have introduced a shelly 4 channel relay that controls my motorized valves (MVs)for hot water (0), upstairs rads (1) downstairs UFH (2) and then the boiler call (3) separately.
The problem i have with keeping the existing dumb system in place and overlaying the relays is when I need to call the boiler and MVs under different scenarios, such as upstairs TRVs to the master zone upstairs relay (1) and the boiler (3), or/and the downstairs ufh actuators to the downstairs master zone relay (2) and the boiler (3).
What i want to do is operate the heating zones as 2 master zones (up and down), that are individually controlled by sub zones, kitchen, lounge for down and bed 1 and 2 up.
Im using vtherm at the mo to create my thermostats for the room
As far as i can see I would need to either link all my downstairs vtherm thermostats to a master configuration for downstairs and another master configuration for upstairs that can open the related valve and call via a single centralised boiler call on or off (probably best)
or!
2 central configurations that call the motorised valves and the boiler via a swicth sequence, that i can allocate to up and one to down stair sub vtherms.
open to other logics as well if anyone has any?
The problem i have is none of the integrations seem to allow these logics, they only allow sub zones to a a single master. I cant believe im the only person with this problem. Some one must of solved this already, i cant be the only one scratching there head ![]()
