HeatIt integrations and sensor definitions
This isn’t really a big of an issue, but I just wanted to understand why it’s configured like this.
The first air temperature listing is the actual air temperature (inside thermostat).
Air temperature 3 is external mounted sensor
Air temperature 4 (which I use) is floor sensor.
Why do they get these names? I have 10 of these thermostats, and they’re all the same.
It’s nice that I can utilize all values, but why are they all named air temperature?
They are the default names the integration provides. You can easily change them. Click on the entity, click on the cog icon at the top of the pop-up card. Change the name and entity_id to something more meaningful to you. Preferably before using them in automations or scripts.
I see. So is this from the person that created the integration, or is it from the device itself?
I used Homey before, and they were listed with the correct names in that system.
