Heatit Z-relay 25A not updating temp values after specified time
Hi, I have a problem with Heatit Z-relay 25A, when temp values are not updating. Or better to say, they update after about 6 hours, even when parameters 7 and 8 are set to any value. I use Zwave JS integration with AEOTEC Z-Stick 7 (FW: 7.21.4).
All other parameters seams to work. DO I have to switch to Z-Wave JS to MQTT, or can this be resolved on normal Z-Wave JS? Thank you
Your Heatit Z-Relay 25A temperature update issue (occurring only every 6 hours despite parameter settings) is likely a configuration problem within Z-Wave JS, not a limitation requiring a switch to Z-Wave JS to MQTT. First, meticulously verify parameters 7 and 8 and the tollbyplate com device’s association groups in Z-Wave JS, ensuring your controller is associated correctly for temperature reporting. Try re-interviewing the device and check for firmware updates for both the Heatit Z-Relay and your AEOTEC Z-Stick 7. If the problem persists after these checks, seek help on Home Assistant or Z-Wave JS community forums before considering a switch to Z-Wave JS to MQTT.
How can I change node associations between the Z-relay and the gateway node to be set as “multchannel” in official Z-wave js?
