For a few weeks I’ve been searching for a good solution, that covers my odd situation.
I have a heatpump, which switches from cold/heat automatically, but is not reliable.
The cold/warmt is distributed by a big radiator and a fan, which is controlled by a rather useless bimetal thermostat.
For now I only have cold somewhat covered (just blow as hard and long as possible while the zigbee temperature sensor tells HASS it’s on the cold setting). But that needs to be easily adjustable by a dial.
There seem to be a lot of templates, integrations, but all seem to have one thing in commong - they all assume you have control over the heatpump. This I do not. I can only control the radiator fan.
Does any of you have tips or hints, how I would achieve this?
I would very much like to avoid the unreliable cold/hot setting of the heatpump blasting heat in my home until it’s the same temperature as the heat pump, the very thing why I’m trying to automate it.
My automation so far, pretty basic:
alias: climate control, cold (Duplicate) (Duplicate)
description:
- platform: homeassistant
event: start
value_template: >-
{{ states('sensor.buienradar_temperature') | float >= 18 and
states('sensor.lumi_lumi_weather_0cba8906_temperature') | float <30 and
states('sensor.lumi_lumi_weather_temperature') | float >=24 }}
condition:
- condition: template
value_template: >-
- type: turn_on
device_id: 01d128e0d1c46e3bed0e13745e6c03f9
entity_id: switch.climate_control_switch_facb6ffe_on_off
domain: switch
- service: notify.notify
message: >-
Climate control turned {{
states('switch.climate_control_switch_facb6ffe_on_off') }}.
- wait_for_trigger:
value_template: >-
{{ states('sensor.lumi_lumi_weather_0cba8906_temperature') | float
>=30 and states('sensor.lumi_lumi_weather_temperature') | float <=25
continue_on_timeout: false
- type: turn_off
domain: switch
message: >-
mode: restart
Outside temp: sensor.buienradar_temperature
Room temp: sensor.lumi_lumi_weather_temperature
Heatpump temp: sensor.lumi_lumi_weather_0cba8906_temperature
Radiator fan switch: switch.climate_control_switch_facb6ffe_on_off
The heatpump cold/warm cycle is recognizable with the heatpump temperature sensor dipping above or below 30 degrees celcius.
Any tips or hints will be greatly appreciated!
