Heiman HS1SA-M matter Integration
Hello, it is about a smoke sensor Heiman HS1SA in the matte version. I watched some videos about matter over thread integration and want to use my Amazon Echo as a boarder router. The integration into the Alexa app also worked, only the code for logging in HA is not generated. Anyone facing the same problem?
Thanks for reaching out. Some Matter and Thread devices are a bit cumbersome to integrate at first.
So this is your first Thread device in HA? Did it work that HA recognizes its Thread network?
I’m not sure what do you mean by that… You added the smoke sensor into the Amazon platform?
So you’re trying to add the smoke sensor first to Amazon, then to HA (not the “new device” option)?
Thanks for your reply. Meanwhile I solved my problem with the Aquara M100 Hub. I realized that you cannot use the Amazon Echo as TBR because the credentials are not available.
