Hello, i am trying to install home assistant on oscal pad 10 android 12 using termux but its always giving error aboit uv wheels
Hello, i am trying to install home assistant on oscal pad 10 android 12 using termux but its always giving error aboit uv wheels . Please i need help, i tried everything also i asked chatgpt for help but still same error please anyone?
Try a supported installation method instead.
So you mean it wont work on android?
Even if some fiddler has got it to work on Android, it’s not supported and you are unlikely to find any support in these forums. The link Tom provided lists the supported platforms, with installation instructions for each.
The Home Assistant backend is meant to be run on a Linux server.
Android can be used to run the frontend part as either the Home Assistant Companion app or as a browser viewing the website presented by the backend
