Testing configuration at /config
ERROR:homeassistant.util.yaml:mapping values are not allowed here
in “/config/switch/rf_outlets.yaml”, line 72, column 16
ERROR:homeassistant.bootstrap:Error loading /config/configuration.yaml: mapping values are not allowed here
Failed config
General Errors:
- Error loading /config/configuration.yaml: mapping values are not allowed here
To get the code formatted correctly for the forum paste the code in
the edit box, leaving a blank line at the start and end, then select
the code and click the </> button in the small menu bar at the top of
the edit box.
