Help asked with temperature automation
A question from a newbee.
I have a HUE outdoor sensor. This detects movement but also has a temperature and lux sensor. These can be seen in home assistant. The motion sensor works okay but automations with temperature and lux do not work. I’m new to home assistant so I must be doing something wrong. Who helps me on my way.
Purpose: Turn on HUE lamp when the temperature is below 25 degrees.
Purpose: turn on HUE lamp if light_leven < 0.
Sensors:
sensor.hue_outdoor_motion_sensor_1_temperature ->16,17 C
binary_sensor.hue_outdoor_motion_sensor_1_motion
sensor.hue_outdoor_motion_sensor_1_light_level ->1.057,55
Lamp:
light.bollamp
————————yaml
alias: A1 Turn on bollamp onder 25 graden
description: A1 Turn on bollamp onder 25 graden
  - platform: numeric_state
    entity_id: sensor.hue_outdoor_motion_sensor_1_temperature
    below: '25.00'
condition: []
  - type: turn_on
    device_id: b608cab4c1114a4a2cd1448d455ff617
    entity_id: light.bollamp
    domain: light
    brightness_pct: 100
mode: single
Thanks, Peter
This will only trigger if the temperature was above 25°C, and then drops below 25°C. If the temperature stays below 25°C it does not.
Since you probably live in the Netherlands or Belgium, that will not happen much any more for the next few months, so you better rethink your trigger.
Thanks for the quick answer. I spent all day yesterday and couldn’t get it to work. I didn’t know that it only worked if the temperature had to be below the set value first. Your answer makes it all clear now. Thank you.
