I’m trying to create a boolean-type template sensor. I tested the template in developer’s tools and it seems to be working, when I added the code to the configuration.yaml file, I get validation errors. Here is what I added:
template:
- sensor:
- name: "Anyone_home"
- unique_id: template.anyone_home
- state: <
{{ if
states('device_tracker.moto_z4') == 'home' or
states('device_tracker.lm_g710vm') == 'home' or
states('device_tracker.sm_g781v') == 'home' }}
true
{{ else }}
false
{{ endif }}
And here is the error messages I receive:
Error loading /config/configuration.yaml: while scanning a simple key
in “/config/configuration.yaml”, line 109, column 1
could not find expected ‘:’
in “/config/configuration.yaml”, line 112, column 45
Line 109 is the beginning of the actual template.
Any help would be appreciated.
Mike.
