hopefully it’s fine
Hi everyone, 2 days since applying the last automation
Day 1: Automation didn’t complete successfully because it failed to see power changing from above 40w to below 20w due automation restarting 16 minutes after originally starting so I worked out what was causing it and rectified it.
Day 2: Automation started like it should without restarting like day 1 and all steps completed successfully.
can someone take a look at the last automation and tell if it cancel at anytime if tv is turned on or just at the 2nd to last stage
