Help creating template to get min and max values from an attribute of several sensors
Hi All,
I have a number of statistics sensors called 1_week_lounge_temperature, 1_week_kitchen_temperature, etc.
I want to create two template sensors, one to contain the highest value from the max_value attribute of each of the statistics sensors and the other to contain the lowest value from the min_value attribute.
Problem is, I have pretty much no idea where to start :slight_smile:
I could probably create a load of template sensors to where the state is the equal to the attributes and then use Min/Max sensors but there must be a more elegant way.
Anyone got any thoughts?
thanks in advance
I ended up doing it like this - can’t help wondering if there’s not a better way. I don’t like having to manually list all of the sensors to check when there is a distinct pattern to the naming.
    sensors:
      max_temp:
        value_template: >-
          {% set sensors = [
            state_attr('sensor.1_week_lounge_temperature', 'max_value')|float,
            state_attr('sensor.1_week_kitchen_temperature', 'max_value')|float,
            state_attr('sensor.1_week_bedroom_temperature', 'max_value')|float,
            state_attr('sensor.1_week_study_temperature', 'max_value')|float,
          {{ sensors|max }}
If you don’t list all the sensor entities somewhere (within the template like you’ve done and/or by listing them in the entity_id option) then Home Assistant won’t know which entities to monitor (for state-changes) and the Template Sensor won’t get updated.
So although it may be tempting to iterate through the entities using a loop that constructs each entity’s name (because they follow a naming pattern), that technique will prevent Home Assistant from discovering the entities it must monitor.
Ah, ok. I’ve not done much templating before so hadn’t realised that. I’ll leave it as it is.
