About every hour (not exact, can be between HH:10 and HH:23, I see below error popping up. In the minute/seconds before or after this error, I cannot find any lead too.
Any ideas how to analyse this to get to the root-cause?
I verified automations and neither spook or watchman kick back issues
2025-03-14 06:24:06.765 ERROR (SyncWorker_8) [homeassistant] Error doing job: Task exception was never retrieved (None)
File "/usr/local/lib/python3.13/site-packages/voluptuous/schema_builder.py", line 205, in __call__
return self._compiled([], data)
File "/usr/local/lib/python3.13/site-packages/voluptuous/validators.py", line 256, in _run
return self._exec(self._compiled, value, path)
File "/usr/local/lib/python3.13/site-packages/voluptuous/validators.py", line 315, in _exec
raise error if self.msg is None else AnyInvalid(self.msg, path=path)
voluptuous.error.AnyInvalid: At least one of entity_id, domains, or entity_globs must have a value
File "/usr/src/homeassistant/homeassistant/components/script/__init__.py", line 707, in _async_run
return await self.script.async_run(script_vars, context)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 1828, in async_run
return await asyncio.shield(create_eager_task(run.async_run()))
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 460, in async_run
await self._async_step(log_exceptions=False)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 526, in _async_step
self._handle_exception(
ex, continue_on_error, self._log_exceptions or log_exceptions
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 556, in _handle_exception
raise exception
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 524, in _async_step
await getattr(self, handler)()
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 1009, in _async_step_call_service
response_data = await self._async_run_long_action(
...<9 lines>...
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 624, in _async_run_long_action
return await long_task
File "/usr/src/homeassistant/homeassistant/core.py", line 2759, in async_call
processed_data: dict[str, Any] = handler.schema(service_data)
File "/usr/local/lib/python3.13/site-packages/voluptuous/validators.py", line 259, in __call__
return self._exec((Schema(val) for val in self.validators), v)
File "/usr/local/lib/python3.13/site-packages/voluptuous/validators.py", line 386, in _exec
raise e if self.msg is None else AllInvalid(self.msg, path=path)
File "/usr/local/lib/python3.13/site-packages/voluptuous/validators.py", line 382, in _exec
v = func(v)
File "/usr/local/lib/python3.13/site-packages/voluptuous/schema_builder.py", line 209, in __call__
raise er.MultipleInvalid([e])
voluptuous.error.MultipleInvalid: At least one of entity_id, domains, or entity_globs must have a value
