I am relatively new to HA and trying to figure something out. I have searched around, but not found a close enough match. Perhaps somebody would be kind enough to point me in the right direction or to give me some suggestions.
I have a carrier HVAC which I have integrated into HA. I would like to have a menu driven option that would change the fan operation. I typically set it to “auto”. Under certain circumstances, I would like to have it on a constant run for a configurable amount of time. For example, I would like to be able to choose to run it for 15 minutes, after which it would resume to “auto”. The time should be something that is selectable. It would also be nice to be able to select the fan run speed (high, med, low) at the same time.
Create two input selects (in yaml or from the helpers UI).
input_select:
fan_speed:
options:
- High
- Med
- Low
fan_run_time:
name: Run Time (Minutes)
options:
- 5
- 10
- 15 # add as many as you want
Add those helpers to a card in your dashboard.
Create an automation to monitor them for changes and to action them when they do change:
Note: these helpers and automations will probably require some adjustements. Go to Developer Tools → States and look at what your actual fan speeds are listed as, then post them here. e.g. here are two of mine:
