Help for binary sensor template
Hello guys,
I wanted to make these binary sensors to make my washing machine smart. Use of shelly plug s with power monitor. The problem is that it doesn’t create entities. I checked the log and there are no errors. what did i do wrong?
here my pastebin: https://pastebin.com/WvF9MQ4r
  sensors:
    stufa_pellet:
      friendly_name: "Stato Stufa a Pellet"
      device_class: power
      delay_on:
        seconds: 30
      delay_off:
        minutes: 5
      value_template: "{{ states('sensor.shellyplug_s_9dcb1c_power')|float > 10 }}"
    lavatrice:
      friendly_name: "Stato Lavatrice"
      device_class: power
      value_template: "{{ states('sensor.lavatrice_power')|int > 0 }}"
      delay_on:
        seconds: 30
      delay_off:
        minutes: 5
    riscaldamento_lavatrice:
      value_template: "{{ states('sensor.lavatrice_power')|float > 1500 }}"
      delay_on:
        minutes: 2
      delay_off:
        minutes: 2
    lavaggio_lavatrice:
      value_template: "{{ states('sensor.lavatrice_power')|int < 1500 and states('sensor.lavatrice_power')|int > 400 }}"
      delay_on:
        minutes: 2
      delay_off:
        minutes: 2
    risciacquo_lavatrice:
      value_template: "{{ states('sensor.lavatrice_power')|int < 400 and states('sensor.lavatrice_power')|int > 0 }}"
      delay_on:
        minutes: 2
      delay_off:
        minutes: 2
Code looks fine, some of the templates can be simplified but not by much. i.e. this:
can be simplified to
"{{ 400 < states('sensor.lavatrice_power')|int < 1500 }}"
but that’s not your problem.
Are you including the file in your configuration.yaml?
Are you reloading templates after you add these?
yes i mapped wity include
I just restart only hass
thank you for reply
