Help for Sauna timer
hi, i try to setup some timer . the problem is at the end not jump to idle but stay at Active.
after is select a sauna mode will statrt the timer for 1 hour… between this time u cant select other sauna mode. after this 1 hour jump to cool down , this time u cant select any of the mode. after the cool down time should go to idle and reset the sauna. right now its working if i select manual cooldown finish. please for help
config : # Loads default set of integrations. Do not remove.
default_config:
# Load frontend themes from the themes folder
frontend:
  themes: !include_dir_merge_named themes
script: !include scripts.yaml
scene: !include scenes.yaml
# Input select for sauna mode
input_select:
  sauna_mode:
    options:
      - Izklop
      - Turška
      - Infra
      - Finska
    initial: Izklop
    icon: mdi:sauna
# Timer definitions
timer:
  sauna_active:
    duration: "00:01:00"
  sauna_cooldown:
# Sensor definitions
    sensors:
      sauna_temperature:
        friendly_name: "Sauna Temperature"
        value_template: "{{ state_attr('climate.sauna1_thermobox_thermostat', 'current_temperature') }}"
        unit_of_measurement: "°C"
automations.yaml:
# Automation to manage sauna modes
- alias: Set Sauna Mode
  - platform: state
    entity_id: input_select.sauna_mode
  - choose:
      - conditions:
          - condition: state
            state: "Izklop"
        sequence:
          - service: switch.turn_off
              entity_id:
                - switch.sauna2_switchbox_0_relay_0
                - switch.sauna3_switchbox_0_relay_0
          - service: climate.set_hvac_mode
              entity_id: climate.sauna1_thermobox_thermostat
              hvac_mode: "off"
      - conditions:
          - condition: state
            state: "Turška"
        sequence:
          - service: switch.turn_on
              entity_id: switch.sauna2_switchbox_0_relay_0
              entity_id: switch.sauna3_switchbox_0_relay_0
              hvac_mode: "off"
      - conditions:
          - condition: state
            state: "Infra"
        sequence:
              hvac_mode: "off"
      - conditions:
          - condition: state
            state: "Finska"
        sequence:
              hvac_mode: "heat"
          - service: climate.set_temperature
              temperature: 90
              entity_id:
  - service: timer.start
      entity_id: timer.sauna_active
- alias: Log Sauna Mode State
  - platform: state
  - service: system_log.write
      message: "Sauna Mode changed to {{ states('input_select.sauna_mode') }}"
# Automation to turn off sauna after the active timer finishes
- alias: Turn Off Sauna After Active Timer
  - platform: event
    event_type: timer.finished
    event_data:
      entity_id:
      hvac_mode: "off"
  - service: input_select.select_option
      option: "Izklop"
      entity_id: timer.sauna_cooldown
- alias: Prevent Sauna Mode Change During Cooldown
  - platform: state
    to: "active"
      option: "Izklop"
- alias: Block Mode Selection During Cooldown
  - platform: event
    event_type: timer.started
    event_data:
  - service: input_select.set_options
      options:
        - Cooldown
      option: Cooldown
- alias: Restore Mode Selection After Cooldown
  - platform: event
    event_data:
      options:
        - Izklop
        - Turška
        - Infra
        - Finska
      option: Izklop
