Help for those where History and Logbook isn't working
Hey guys yes i know its uncatogarised and yeah my english has its problems im a native german. But today i finally fixed my history and logbook in a way i havent read in months i dont know why nobody writes about this hopefully i can help some fellow tinkerers with my solution.
So i got a problem some months back where after a HA OS update my whole history and such was missing now i tried it with a AI to get some other insides cause i never read about the same problem on the forum so if youre having trouble with your database you deleted it tried differend recorders and such just try ading following to your configuration yaml:
history:
energy:
logbook:
jeah youre thinking exactly what i was thinking but trust me it works. apparently if youre switching from some old versions to the new ones there was a switch in how these integrations are handled in homeassistant so i didnt have a so called default config so ha didnt thought about initialising these i tried deleting my database multible times canging my recorder and database noething seemed to work but now everything is showing up after multible months.
so just try it if youre having the same trubles as me.
and otherwise fellow users stay safe and keep tinkering i absolutely love this community. As specially as an Elektritian here in Germany.
in high regards Michel <3
You can always just add default_config to your configuration.yaml file...
default_config:
Save the file and restart Home Assistant and you're good to go.
Did you perhaps remove it at some point in the past?
