Hi guys,
Having some issues with Frigate add-on on my environment. It gets fixed every time I restart the add-on. So it basically stop producing the snapshots of events, and I can’t really access the Frigate web gui.
Getting these errors in the add-on log file:
File “/usr/local/lib/python3.8/dist-packages/flask/app.py”, line 2242, in preprocess_request
rv = func()
File “/opt/frigate/frigate/http.py”, line 89, in _db_connect
database.connect()
File “/usr/local/lib/python3.8/dist-packages/peewee.py”, line 3061, in connect
raise OperationalError(‘Connection already opened.’)
peewee.OperationalError: Connection already opened.
2021-07-05T01:29:18Z {‘REMOTE_ADDR’: ‘127.0.0.1’, ‘REMOTE_PORT’: ‘54674’, ‘HTTP_HOST’: ‘192.168.0.250’, (hidden keys: 30)} failed with OperationalError
File “/usr/local/lib/python3.8/dist-packages/flask_sockets.py”, line 40, in call
handler, values = adapter.match()
File “/usr/local/lib/python3.8/dist-packages/werkzeug/routing.py”, line 1945, in match
raise NotFound()
werkzeug.exceptions.NotFound: 404 Not Found: The requested URL was not found on the server. If you entered the URL manually please check your spelling and try again.
File “/usr/local/lib/python3.8/dist-packages/gevent/pywsgi.py”, line 999, in handle_one_response
self.run_application()
File “/usr/local/lib/python3.8/dist-packages/geventwebsocket/handler.py”, line 87, in run_application
return super(WebSocketHandler, self).run_application()
File “/usr/local/lib/python3.8/dist-packages/gevent/pywsgi.py”, line 945, in run_application
self.result = self.application(self.environ, self.start_response)
File “/usr/local/lib/python3.8/dist-packages/flask/app.py”, line 2464, in call
return self.wsgi_app(environ, start_response)
File “/usr/local/lib/python3.8/dist-packages/flask_sockets.py”, line 48, in call
File “/usr/local/lib/python3.8/dist-packages/flask/app.py”, line 2450, in wsgi_app
response = self.handle_exception(e)
File “/usr/local/lib/python3.8/dist-packages/flask/app.py”, line 1867, in handle_exception
reraise(exc_type, exc_value, tb)
File “/usr/local/lib/python3.8/dist-packages/flask/_compat.py”, line 39, in reraise
raise value
File “/usr/local/lib/python3.8/dist-packages/flask/app.py”, line 2447, in wsgi_app
response = self.full_dispatch_request()
File “/usr/local/lib/python3.8/dist-packages/flask/app.py”, line 1952, in full_dispatch_request
rv = self.handle_user_exception(e)
File “/usr/local/lib/python3.8/dist-packages/flask/app.py”, line 1821, in handle_user_exception
raise value
File “/usr/local/lib/python3.8/dist-packages/flask/app.py”, line 1948, in full_dispatch_request
rv = self.preprocess_request()
rv = func()
database.connect()
2021-07-05T01:29:18Z {‘REMOTE_ADDR’: ‘127.0.0.1’, ‘REMOTE_PORT’: ‘54676’, ‘HTTP_HOST’: ‘192.168.0.250’, (hidden keys: 30)} failed with OperationalError
raise NotFound()
raise value
raise value
rv = func()
database.connect()
2021-07-05T01:29:18Z {‘REMOTE_ADDR’: ‘127.0.0.1’, ‘REMOTE_PORT’: ‘54678’, ‘HTTP_HOST’: ‘192.168.0.250’, (hidden keys: 30)} failed with OperationalError
Any ideas what causing this behavior?
Regards,
Didi
