I have a Wemos D1 Mini for my experiments (name: wemosswitch). It currently works with various sensors, switches, etc. I want to experiment with deep sleep next. So, I solder the bridge from GPIO16 to Reset on the Wemos board. When I plug it back in to my USB port, the log shows that it won’t connect to wemosswitch.local
From the ESPHome console I edit the YAML for the device and add:
deep_sleep:
run_duration: 120s
sleep_duration: 0min
And, it still doesn’t connect. Ironically, I can edit and upload new code just fine.
Questions:
- What is the result of running the code without the deep_sleep component, but with GPIO16-RST connected?
- What is the default value of run_duration and sleep_duration? (The docs only say the parameters are optional).
