Help : hassio keeps crashing
Help.
I’m having crashes all of a sudden and I can’t work it out.
I am running on virtual box7 on windows…has run perfectly til not that long ago.
Now it won’t let me upgrade and it keeps spitting out this error.
Error during setup of component hassio
10:57:31 PM – (ERROR) components/hassio/handler.py
Can’t read panel info: System is not ready with state: setup
10:57:31 PM – (ERROR) hassio
Can’t read Supervisor data: System is not ready with state: setup
10:57:31 PM – (WARNING) hassio
Not connected with the supervisor / system too busy!
10:57:30 PM – (WARNING) hassio
The logs show
2022-11-17 22:57:30.749 WARNING (MainThread) [homeassistant.components.hassio] Not connected with the supervisor / system too busy!
2022-11-17 22:57:31.173 WARNING (MainThread) [homeassistant.components.hassio] Can’t read Supervisor data: System is not ready with state: setup
2022-11-17 22:57:31.280 ERROR (MainThread) [homeassistant.components.hassio.addon_panel] Can’t read panel info: System is not ready with state: setup
2022-11-17 22:57:31.301 ERROR (MainThread) [homeassistant.setup] Error during setup of component hassio
File “/usr/src/homeassistant/homeassistant/components/hassio/init.py”, line 765, in async_setup
File “/usr/src/homeassistant/homeassistant/components/hassio/repairs.py”, line 149, in setup
File “/usr/src/homeassistant/homeassistant/components/hassio/repairs.py”, line 157, in update
File “/usr/src/homeassistant/homeassistant/components/hassio/handler.py”, line 45, in _wrapper
raise HassioAPIError(data[“message”])
homeassistant.components.hassio.handler.HassioAPIError: System is not ready with state: setup
Full logs
2022-11-17 23:05:49.122 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration browser_mod which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-11-17 23:05:49.126 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration govee which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-11-17 23:05:49.130 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration shelly which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-11-17 23:05:49.134 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration solis which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-11-17 23:05:49.137 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration auto_backup which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-11-17 23:05:49.141 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration dahua which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-11-17 23:05:49.145 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration octopus_energy which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-11-17 23:05:49.149 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration better_thermostat which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-11-17 23:05:49.156 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-11-17 23:05:49.160 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration heatmiserneo which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-11-17 23:05:49.163 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration watchman which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-11-17 23:05:49.167 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration ui_lovelace_minimalist which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-11-17 23:05:49.171 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration heatmiser_wifi which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-11-17 23:05:49.174 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration solarman which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-11-17 23:05:49.177 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration pfsense which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-11-17 23:05:49.181 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration hildebrandglow_dcc which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-11-17 23:05:51.881 WARNING (MainThread) [homeassistant.components.hassio] Not connected with the supervisor / system too busy!
2022-11-17 23:05:52.369 WARNING (MainThread) [homeassistant.components.hassio] Can’t read Supervisor data: System is not ready with state: setup
2022-11-17 23:05:52.393 ERROR (MainThread) [homeassistant.components.hassio.addon_panel] Can’t read panel info: System is not ready with state: setup
2022-11-17 23:05:52.411 ERROR (MainThread) [homeassistant.setup] Error during setup of component hassio
File “/usr/src/homeassistant/homeassistant/setup.py”, line 235, in _async_setup_component
result = await task
await repairs.setup()
await self.update()
data = await self._client.get_resolution_info()
2022-11-17 23:05:56.111 WARNING (MainThread) [homeassistant.helpers.frame] Detected integration that uses deprecated async_get_registry to access entity registry, use async_get instead. Please report issue to the custom integration author for shelly using this method at custom_components/shelly/init.py, line 356: await self.hass.helpers.entity_registry.async_get_registry()
2022-11-17 23:05:58.161 WARNING (MainThread) [homeassistant.components.mqtt.mixins] Manually configured MQTT sensor(s) found under platform key ‘sensor’, please move to the mqtt integration key, see MQTT Sensor - Home Assistant
2022-11-17 23:05:59.058 ERROR (MainThread) [homeassistant.components.forecast_solar] Unexpected error fetching forecast_solar data: Rate limit for API calls reached. (error 429)
File “/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py”, line 205, in _async_refresh
self.data = await self._async_update_data()
File “/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py”, line 164, in _async_update_data
return await self.update_method()
File “/usr/local/lib/python3.10/site-packages/forecast_solar/init.py”, line 148, in estimate
data = await self._request(
File “/usr/local/lib/python3.10/site-packages/forecast_solar/init.py”, line 122, in _request
raise ForecastSolarRatelimit(data[“message”])
forecast_solar.exceptions.ForecastSolarRatelimit: Rate limit for API calls reached. (error 429)
2022-11-17 23:05:59.065 WARNING (MainThread) [homeassistant.config_entries] Config entry ‘Home’ for forecast_solar integration not ready yet: Rate limit for API calls reached. (error 429); Retrying in background
2022-11-17 23:05:59.066 ERROR (MainThread) [homeassistant.components.forecast_solar] Unexpected error fetching forecast_solar data: Rate limit for API calls reached. (error 429)
2022-11-17 23:05:59.068 WARNING (MainThread) [homeassistant.config_entries] Config entry ‘Home’ for forecast_solar integration not ready yet: Rate limit for API calls reached. (error 429); Retrying in background
2022-11-17 23:06:00.983 ERROR (MainThread) [homeassistant.setup] Setup failed for custom integration heatmiserneo: Unable to import component: cannot import name ‘NeoHub’ from ‘neohubapi.neohub’ (/usr/local/lib/python3.10/site-packages/neohubapi/neohub.py)
2022-11-17 23:06:02.177 WARNING (MainThread) [homeassistant.components.home_connect] The ‘home_connect’ option near /config/configuration.yaml:0 is deprecated, please remove it from your configuration
2022-11-17 23:06:02.184 WARNING (MainThread) [homeassistant.components.home_connect] Configuration of Home Connect integration in YAML is deprecated and will be removed in a future release; Your existing OAuth Application Credentials have been imported into the UI automatically and can be safely removed from your configuration.yaml file
2022-11-17 23:06:03.946 ERROR (MainThread) [homeassistant.helpers.template] Template variable error: ‘dict object’ has no attribute ‘power’ when rendering ‘{{ value_json.gasmeter.power.value | float * 1000 |int }}’
2022-11-17 23:06:03.998 ERROR (MainThread) [homeassistant.helpers.template] Template variable error: ‘dict object’ has no attribute ‘export’ when rendering ‘{{ value_json.gasmeter.energy.export.cumulative | float |round(1) }}’
2022-11-17 23:06:05.676 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0xBF19:1:0x0006]: ‘async_initialize’ stage failed: ‘power_on_state’
2022-11-17 23:06:05.682 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0xBF19:2:0x0006]: ‘async_initialize’ stage failed: ‘power_on_state’
2022-11-17 23:06:05.683 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x9557:1:0x0006]: ‘async_initialize’ stage failed: ‘power_on_state’
2022-11-17 23:06:05.685 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x9557:2:0x0006]: ‘async_initialize’ stage failed: ‘power_on_state’
2022-11-17 23:06:05.761 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0xBF19:1:0x0006]: ‘async_initialize’ stage failed: ‘power_on_state’
2022-11-17 23:06:05.762 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0xBF19:2:0x0006]: ‘async_initialize’ stage failed: ‘power_on_state’
2022-11-17 23:06:05.762 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x9557:1:0x0006]: ‘async_initialize’ stage failed: ‘power_on_state’
2022-11-17 23:06:05.763 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x9557:2:0x0006]: ‘async_initialize’ stage failed: ‘power_on_state’
2022-11-17 23:06:11.010 WARNING (MainThread) [homeassistant.components.homeassistant.triggers.numeric_state] Error initializing ‘Inverter temp under 40c turn off’ trigger: In ‘numeric_state’ condition: entity sensor.solis_inverter_temperature state ‘°C’ cannot be processed as a number
2022-11-17 23:06:12.102 ERROR (MainThread) [homeassistant.components.forecast_solar] Unexpected error fetching forecast_solar data: Rate limit for API calls reached. (error 429)
2022-11-17 23:06:12.103 ERROR (MainThread) [homeassistant.components.forecast_solar] Unexpected error fetching forecast_solar data: Rate limit for API calls reached. (error 429)
2022-11-17 23:06:12.137 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x030F:11:0x0008]: async_initialize: all attempts have failed: [DeliveryError(‘Failed to deliver packet: <TXStatus.NWK_ROUTE_DISCOVERY_FAILED: 208>’), DeliveryError(‘Failed to deliver packet: <TXStatus.NWK_ROUTE_DISCOVERY_FAILED: 208>’), DeliveryError(‘Failed to deliver packet: <TXStatus.NWK_ROUTE_DISCOVERY_FAILED: 208>’), DeliveryError(‘Failed to deliver packet: <TXStatus.NWK_ROUTE_DISCOVERY_FAILED: 208>’)]
2022-11-17 23:06:12.149 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x5080:11:0x0008]: async_initialize: all attempts have failed: [DeliveryError(‘Failed to deliver packet: <TXStatus.NWK_ROUTE_DISCOVERY_FAILED: 208>’), DeliveryError(‘Failed to deliver packet: <TXStatus.NWK_ROUTE_DISCOVERY_FAILED: 208>’), DeliveryError(‘Failed to deliver packet: <TXStatus.NWK_ROUTE_DISCOVERY_FAILED: 208>’), DeliveryError(‘Failed to deliver packet: <TXStatus.NWK_ROUTE_DISCOVERY_FAILED: 208>’)]
2022-11-17 23:06:13.833 ERROR (MainThread) [homeassistant.helpers.template] Template variable error: ‘dict object’ has no attribute ‘power’ when rendering ‘{{ value_json.gasmeter.power.value | float * 1000 |int }}’
2022-11-17 23:06:13.836 ERROR (MainThread) [homeassistant.helpers.template] Template variable error: ‘dict object’ has no attribute ‘export’ when rendering ‘{{ value_json.gasmeter.energy.export.cumulative | float |round(1) }}’
2022-11-17 23:06:23.858 ERROR (MainThread) [homeassistant.helpers.template] Template variable error: ‘dict object’ has no attribute ‘power’ when rendering ‘{{ value_json.gasmeter.power.value | float * 1000 |int }}’
2022-11-17 23:06:23.859 ERROR (MainThread) [homeassistant.helpers.template] Template variable error: ‘dict object’ has no attribute ‘export’ when rendering ‘{{ value_json.gasmeter.energy.export.cumulative | float |round(1) }}’
2022-11-17 23:06:27.951 WARNING (MainThread) [homeassistant.components.home_connect] The ‘home_connect’ option is deprecated, please remove it from your configuration
2022-11-17 23:06:30.819 WARNING (MainThread) [homeassistant.components.homeassistant.triggers.numeric_state] Error in ‘Inverter temp under 40c turn off’ trigger: In ‘numeric_state’ condition: entity sensor.solis_inverter_temperature state ‘°C’ cannot be processed as a number
2022-11-17 23:06:33.876 ERROR (MainThread) [homeassistant.helpers.template] Template variable error: ‘dict object’ has no attribute ‘power’ when rendering ‘{{ value_json.gasmeter.power.value | float * 1000 |int }}’
2022-11-17 23:06:33.878 ERROR (MainThread) [homeassistant.helpers.template] Template variable error: ‘dict object’ has no attribute ‘export’ when rendering ‘{{ value_json.gasmeter.energy.export.cumulative | float |round(1) }}’
2022-11-17 23:06:43.896 ERROR (MainThread) [homeassistant.helpers.template] Template variable error: ‘dict object’ has no attribute ‘power’ when rendering ‘{{ value_json.gasmeter.power.value | float * 1000 |int }}’
2022-11-17 23:06:43.897 ERROR (MainThread) [homeassistant.helpers.template] Template variable error: ‘dict object’ has no attribute ‘export’ when rendering ‘{{ value_json.gasmeter.energy.export.cumulative | float |round(1) }}’
2022-11-17 23:06:51.118 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x030F:11:0x0006]: async_initialize: all attempts have failed: [DeliveryError(‘Failed to deliver packet: <TXStatus.NWK_ROUTE_DISCOVERY_FAILED: 208>’), DeliveryError(‘Failed to deliver packet: <TXStatus.NWK_ROUTE_DISCOVERY_FAILED: 208>’), DeliveryError(‘Failed to deliver packet: <TXStatus.NWK_ROUTE_DISCOVERY_FAILED: 208>’), DeliveryError(‘Failed to deliver packet: <TXStatus.NWK_ROUTE_DISCOVERY_FAILED: 208>’)]
2022-11-17 23:06:51.127 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x5080:11:0x0006]: async_initialize: all attempts have failed: [DeliveryError(‘Failed to deliver packet: <TXStatus.NWK_ROUTE_DISCOVERY_FAILED: 208>’), DeliveryError(‘Failed to deliver packet: <TXStatus.NWK_ROUTE_DISCOVERY_FAILED: 208>’), DeliveryError(‘Failed to deliver packet: <TXStatus.NWK_ROUTE_DISCOVERY_FAILED: 208>’), DeliveryError(‘Failed to deliver packet: <TXStatus.NWK_ROUTE_DISCOVERY_FAILED: 208>’)]
2022-11-17 23:06:53.420 ERROR (MainThread) [homeassistant.helpers.template] Template variable error: ‘dict object’ has no attribute ‘power’ when rendering ‘{{ value_json.gasmeter.power.value | float * 1000 |int }}’
2022-11-17 23:06:53.422 ERROR (MainThread) [homeassistant.helpers.template] Template variable error: ‘dict object’ has no attribute ‘export’ when rendering ‘{{ value_json.gasmeter.energy.export.cumulative | float |round(1) }}’
2022-11-17 23:07:03.439 ERROR (MainThread) [homeassistant.helpers.template] Template variable error: ‘dict object’ has no attribute ‘power’ when rendering ‘{{ value_json.gasmeter.power.value | float * 1000 |int }}’
2022-11-17 23:07:03.440 ERROR (MainThread) [homeassistant.helpers.template] Template variable error: ‘dict object’ has no attribute ‘export’ when rendering ‘{{ value_json.gasmeter.energy.export.cumulative | float |round(1) }}’
I’m having the same problem… since updated to the latest version 2022.11.4 and hassos 9.3…
Can’t figure out what’s going on, after a few hours it stops working with the same errors as the previous posts!
Anyone out there that can point us to troubleshoot the problem?
I had to start from scratch and use a backup file
I have the same issue on all my VMS all 3 servers having same issue…
