I would like a example of local addon with nodejs and install some packaje.json.
I al trying but i have a error.
Thanks.
Thanks.
this is my code:
ARG BUILD_FROM
FROM $BUILD_FROM
ENV LANG C.UTF-8
RUN apk add --no-cache nodejs nodejs-npm
# use changes to package.json to force Docker not to use the cache
# when we change our application's nodejs dependencies
COPY package.json /tmp/package.json
RUN cd /tmp
RUN npm install
RUN mkdir -p /app
RUN cp -a /tmp/node_modules /app
RUN cd /app
WORKDIR /app
COPY . /app
# Copy data for add-on
#COPY run.sh /
RUN chmod a+x /run.sh
CMD [ "/run.sh" ]
the error is:
docker.errors.BuildError: The command '/bin/sh -c cp -a /tmp/node_modules /app' returned a non-zero code: 1
Did you ever figure it out?
Have a look at https://github.com/helmut-hoffer-von-ankershoffen/hassio-ring-bridge for a NodeJS based addon - in this case a bridge from Home Assistant to Ring
