ISSUE / PROBLEM:
Unable to install / boot HA on a new rPi5 with an m.2 hat / nvme drive.
STEPS TAKEN / OBSERVATIONS:
- Installed Raspberry Pi OS on microSD using Raspberry Pi Imager (v1.8.5) on Windows.
- Installed Home Assistant on NVMe using Raspberry Pi Imager (v1.8.5) on Windows.
- Confirmed Ethernet is connected.
- Booted into rPi OS using microSD. Performed initial setup steps.
- Configured EEPROM from rPi OS terminal to boot from NVMe using the following steps that came with my Argon Neo 5 case:
a.)curl https://download.argon40.com/argon-eeprom.sh|bash
b.) reboot
c.)curl https://download.argon40.com/argonneo5.sh|bash
d.) reboot - Removed microSD.
- Observation 1: Does not boot into HA.
- Theory 1: EEPROM configuration / NVMe boot preference configuration was incorrect
- Test of Theory 1: Removed NVMe and installed Raspberry Pi OS on NVMe → put it back in → restarted device.
- Observation 2: Device boots into Raspberry Pi OS normally (without microSD).
- Conclusion: Theory 1 is not correct.
HARDWARE:
- Raspberry Pi 5
- Case: ARGON NEO 5 M.2 NVME
- NVME drive: MSI Spatium M450 M.2 2280 1TB PCI-Express 4.0 x 4
