Help M5 Atom won't work
This is my first voice device I am setting up. I followed the instructions on the website $13 voice assistant for Home Assistant - Home Assistant. It looks like it was set up fine but I hear nothing from it and it will not respond to my wake word. In the device settings I was able to get to a section where you click test for wake word, and play the voice you hear. When I click play, the light turns blue on the device but I hear nothing. Did I just get a bad unit or did I do something wrong in the configuration?
In the activity section of esp home I can see it turn on, immediately go to idle, and immediately says M5Stack Atom Echo fd5e94 Firmware turned off. Is that normal behavior?
Any help is appreciated, thanks!
HA >> settings >> system >> network
What is local address set there?
it is set to automatic and is the IP address I use to manage my HA in web browsers. I’m not sure if I’m answering that correctly but that is the only thing I see under “local address”
Can you post log from esp?
I have the same issue with two of my M5s - I’m still using the workaround for them while the other two are working fine :confused:
@chairstacker interesting, did you have issues with the mic not responding to your wake word as well, or just issues with the volume like the person in the link said.
I had some issues for a little while - I think it was after I updated the devices with the 2025.9.x ESPHome version.
I had to go back to 2025.7.3 and they are still running on that version.
Couldn’t bring myself to try a newer version yet for these devices.
