Sorry for copying and pasting it all but I’m not sure what’s significant… The one I really want to clear is the pysnmp (device tracker) one as that occurs the most frequently…
Everything is working pretty well but the device tracker error keeps appearing, any ideas why?
Device tracker is SNMP to a mikrotik router using the mib listed on the ha docs… works fine in the ui for presence detection by these errors keep coming…
16-10-04 17:40:26 homeassistant.components.recorder: Ended unfinished session (id=11 from 2016-10-04 16:33:37.785996)
16-10-04 17:40:26 homeassistant.components.recorder: Found unfinished sessions
16-10-04 18:32:00 homeassistant.core: BusHandler:Exception doing job
File "/home/pi/.homeassistant/deps/pysnmp/carrier/asyncore/dispatch.py", line 45, in runDispatcher
use_poll=True, map=self.__sockMap, count=1)
File "/usr/lib/python3.4/asyncore.py", line 212, in loop
poll_fun(timeout, map)
File "/usr/lib/python3.4/asyncore.py", line 193, in poll2
readwrite(obj, flags)
File "/usr/lib/python3.4/asyncore.py", line 123, in readwrite
obj.handle_error()
File "/usr/lib/python3.4/asyncore.py", line 108, in readwrite
obj.handle_read_event()
File "/usr/lib/python3.4/asyncore.py", line 442, in handle_read_event
self.handle_read()
File "/home/pi/.homeassistant/deps/pysnmp/carrier/asyncore/dgram/base.py", line 157, in handle_read
self._cbFun(self, transportAddress, incomingMessage)
File "/home/pi/.homeassistant/deps/pysnmp/carrier/base.py", line 68, in _cbFun
self, transportDomain, transportAddress, incomingMessage
File "/home/pi/.homeassistant/deps/pysnmp/entity/engine.py", line 145, in __receiveMessageCbFun
self, transportDomain, transportAddress, wholeMsg
File "/home/pi/.homeassistant/deps/pysnmp/proto/rfc3412.py", line 458, in receiveMessage
cachedParams['cbCtx'])
File "/home/pi/.homeassistant/deps/pysnmp/entity/rfc3413/cmdgen.py", line 131, in processResponsePdu cbFun(snmpEngine, origSendRequestHandle, None, PDU, cbCtx)
File "/home/pi/.homeassistant/deps/pysnmp/entity/rfc3413/cmdgen.py", line 268, in processResponseVarBinds
varBindTable[-1], v2c.apiPDU.getVarBinds(reqPDU)
File "/home/pi/.homeassistant/deps/pysnmp/entity/rfc3413/cmdgen.py", line 31, in getNextVarBinds
if v2c.ObjectIdentifier(origVarBinds[idx][0]).asTuple() >= varBinds[idx][0].asTuple():
IndexError: list index out of range
File "/usr/local/lib/python3.4/dist-packages/homeassistant/core.py", line 1162, in job_handler
func(*args)
File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/device_tracker/__init__.py", line 425, in device_tracker_scan
for mac in scanner.scan_devices():
File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/device_tracker/snmp.py", line 65, in scan_devices
self._update_info()
File "/usr/local/lib/python3.4/dist-packages/homeassistant/util/__init__.py", line 296, in wrapper
result = method(*args, **kwargs)
File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/device_tracker/snmp.py", line 86, in _update_info
data = self.get_snmp_data()
File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/device_tracker/snmp.py", line 98, in get_snmp_data
self.community, self.host, self.baseoid)
File "/home/pi/.homeassistant/deps/pysnmp/entity/rfc3413/oneliner/cmdgen.py", line 219, in nextCmd
**kwargs):
File "/home/pi/.homeassistant/deps/pysnmp/hlapi/asyncore/sync/cmdgen.py", line 347, in nextCmd
snmpEngine.transportDispatcher.runDispatcher()
File "/home/pi/.homeassistant/deps/pysnmp/carrier/asyncore/dispatch.py", line 49, in runDispatcher
raise PySnmpError('poll error: %s' % ';'.join(format_exception(*exc_info())))
pysnmp.error.PySnmpError: poll error: Traceback (most recent call last):
; File "/home/pi/.homeassistant/deps/pysnmp/carrier/asyncore/dispatch.py", line 45, in runDispatcher
; File "/usr/lib/python3.4/asyncore.py", line 212, in loop
; File "/usr/lib/python3.4/asyncore.py", line 193, in poll2
; File "/usr/lib/python3.4/asyncore.py", line 123, in readwrite
obj.handle_error()
; File "/usr/lib/python3.4/asyncore.py", line 108, in readwrite
; File "/usr/lib/python3.4/asyncore.py", line 442, in handle_read_event
self.handle_read()
; File "/home/pi/.homeassistant/deps/pysnmp/carrier/asyncore/dgram/base.py", line 157, in handle_read self._cbFun(self, transportAddress, incomingMessage)
; File "/home/pi/.homeassistant/deps/pysnmp/carrier/base.py", line 68, in _cbFun
; File "/home/pi/.homeassistant/deps/pysnmp/entity/engine.py", line 145, in __receiveMessageCbFun
; File "/home/pi/.homeassistant/deps/pysnmp/proto/rfc3412.py", line 458, in receiveMessage
; File "/home/pi/.homeassistant/deps/pysnmp/entity/rfc3413/cmdgen.py", line 131, in processResponsePdu
; File "/home/pi/.homeassistant/deps/pysnmp/entity/rfc3413/cmdgen.py", line 268, in processResponseVarBinds
; File "/home/pi/.homeassistant/deps/pysnmp/entity/rfc3413/cmdgen.py", line 31, in getNextVarBinds
;IndexError: list index out of range
16-10-04 19:57:55 homeassistant.components.media_player.kodi: Unable to fetch kodi data
16-10-04 20:01:10 homeassistant.components.media_player.kodi: Unable to fetch kodi data
16-10-04 22:00:10 homeassistant.components.sensor.rest: Error fetching data: <PreparedRequest [GET]>
16-10-04 22:00:10 homeassistant.core: BusHandler:Exception doing job
func(*args)
File "/usr/local/lib/python3.4/dist-packages/homeassistant/helpers/entity_component.py", line 229, in _update_entity_states
entity.update_ha_state(True)
File "/usr/local/lib/python3.4/dist-packages/homeassistant/helpers/entity.py", line 154, in update_ha_state
self.update()
File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/sensor/pi_hole.py", line 101, in update
self._state = json.loads(self.rest.data)
File "/usr/lib/python3.4/json/__init__.py", line 312, in loads
s.__class__.__name__))
TypeError: the JSON object must be str, not 'NoneType'
16-10-04 23:00:10 homeassistant.components.sensor.rest: Error fetching data: <PreparedRequest [GET]>
16-10-04 23:00:10 homeassistant.core: BusHandler:Exception doing job
func(*args)
self.update()
16-10-04 23:11:10 homeassistant.components.sensor.rest: Error fetching data: <PreparedRequest [GET]>
16-10-04 23:11:10 homeassistant.core: BusHandler:Exception doing job
func(*args)
self.update()
16-10-05 00:00:10 homeassistant.components.sensor.rest: Error fetching data: <PreparedRequest [GET]>
16-10-05 00:00:10 homeassistant.core: BusHandler:Exception doing job
func(*args)
self.update()
16-10-05 03:22:11 pychromecast.socket_client: Heartbeat timeout, resetting connection
16-10-05 03:22:18 pychromecast.socket_client: Failed to connect, retrying in 5.000000s
File "/home/pi/.homeassistant/deps/pychromecast/socket_client.py", line 233, in initialize_connection
self.socket.connect((self.host, self.port))
File "/usr/lib/python3.4/ssl.py", line 840, in connect
self._real_connect(addr, False)
File "/usr/lib/python3.4/ssl.py", line 827, in _real_connect
socket.connect(self, addr)
ConnectionRefusedError: [Errno 111] Connection refused
