So I have a lamp over the couch that has 3 smart bulbs in it. I always want them ALL on or ALL off. But sometimes for whatever reason, 1 fails to turn off or on with the others.
I created the flow below to check each one against each other so if 2 are one way and 1 is not, the 1 is made to conform to the 2. Right now I have them being checked against each other when another lamp in the room changes state and every minute.
But there has to be a cleaner way to do this.
"id": "7fb0c6f8a4ad507e",
"type": "tab",
"label": "Flow 2",
"disabled": false,
"info": "",
"env": []
"id": "cf7c317535a9c090",
"type": "api-current-state",
"z": "7fb0c6f8a4ad507e",
"name": "Couch light 1 on?",
"server": "ab3e2c53.e3491",
"version": 3,
"outputs": 2,
"halt_if": "on",
"halt_if_type": "str",
"halt_if_compare": "is",
"entity_id": "light.living_room_couch_lamp1",
"state_type": "str",
"blockInputOverrides": true,
"outputProperties": [
"property": "payload",
"propertyType": "msg",
"value": "",
"valueType": "entityState"
"property": "data",
"value": "",
"valueType": "entity"
"for": "0",
"forType": "num",
"forUnits": "minutes",
"override_topic": false,
"state_location": "payload",
"override_payload": "msg",
"entity_location": "data",
"override_data": "msg",
"x": 645,
"y": 135,
"wires": [
"d5df2e4a86ce652b"
"id": "bd22c467809fc49a",
"type": "inject",
"name": "",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "60",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "",
"payloadType": "date",
"x": 130,
"y": 135,
"wires": [
"cf7c317535a9c090",
"755e1ff0e41c8594",
"5c4360104a8f4f49",
"7b4cf5d1210eedb2",
"ea833815ed243b2c",
"278e5b9dfc8b1efa"
"id": "d5df2e4a86ce652b",
"name": "Couch light 2 on?",
"version": 3,
"outputs": 2,
"halt_if": "on",
"entity_id": "light.living_room_couch_lamp2",
"value": "",
"property": "data",
"value": "",
"for": "0",
"forType": "num",
"x": 855,
"y": 135,
"wires": [
"0b0fa4a0a7805189"
"id": "0b0fa4a0a7805189",
"name": "Couch light 3 on?",
"version": 3,
"outputs": 2,
"halt_if": "on",
"entity_id": "light.living_room_couch_lamp3",
"value": "",
"property": "data",
"value": "",
"for": "0",
"forType": "num",
"x": 1065,
"y": 135,
"wires": [
"0b7c5ffc69e13d4d"
"id": "0b7c5ffc69e13d4d",
"type": "api-call-service",
"name": "ON: Couch light 3",
"version": 7,
"debugenabled": false,
"action": "light.turn_on",
"floorId": [],
"areaId": [],
"deviceId": [],
"entityId": [
"labelId": [],
"data": "",
"dataType": "jsonata",
"mergeContext": "",
"mustacheAltTags": false,
"outputProperties": [],
"queue": "none",
"domain": "light",
"service": "turn_on",
"x": 1275,
"y": 135,
"wires": [
"id": "755e1ff0e41c8594",
"version": 3,
"outputs": 2,
"halt_if": "on",
"value": "",
"property": "data",
"value": "",
"for": "0",
"forType": "num",
"x": 645,
"y": 165,
"wires": [
"c14a15b50c000710"
"id": "c14a15b50c000710",
"version": 3,
"outputs": 2,
"halt_if": "on",
"value": "",
"property": "data",
"value": "",
"for": "0",
"forType": "num",
"x": 855,
"y": 165,
"wires": [
"6538c03ece6bb30b"
"id": "6538c03ece6bb30b",
"version": 3,
"outputs": 2,
"halt_if": "on",
"value": "",
"property": "data",
"value": "",
"for": "0",
"forType": "num",
"x": 1065,
"y": 165,
"wires": [
"836951de1a9e9750"
"id": "836951de1a9e9750",
"name": "ON: Couch light 1",
"version": 7,
"floorId": [],
"areaId": [],
"deviceId": [],
"entityId": [
"labelId": [],
"data": "",
"mergeContext": "",
"queue": "none",
"domain": "light",
"x": 1275,
"y": 165,
"wires": [
"id": "5c4360104a8f4f49",
"version": 3,
"outputs": 2,
"halt_if": "on",
"value": "",
"property": "data",
"value": "",
"for": "0",
"forType": "num",
"x": 645,
"y": 195,
"wires": [
"323a8f0975dadcbd"
"id": "c21e0083907a4bf2",
"version": 3,
"outputs": 2,
"halt_if": "on",
"value": "",
"property": "data",
"value": "",
"for": "0",
"forType": "num",
"x": 1065,
"y": 195,
"wires": [
"10fade48a20eddea"
"id": "323a8f0975dadcbd",
"version": 3,
"outputs": 2,
"halt_if": "on",
"value": "",
"property": "data",
"value": "",
"for": "0",
"forType": "num",
"x": 855,
"y": 195,
"wires": [
"c21e0083907a4bf2"
"id": "10fade48a20eddea",
"name": "ON: Couch light 2",
"version": 7,
"floorId": [],
"areaId": [],
"deviceId": [],
"entityId": [
"labelId": [],
"data": "",
"mergeContext": "",
"queue": "none",
"domain": "light",
"x": 1275,
"y": 195,
"wires": [
"id": "7b4cf5d1210eedb2",
"name": "Couch light 1 off?",
"version": 3,
"outputs": 2,
"halt_if": "off",
"value": "",
"property": "data",
"value": "",
"for": "0",
"forType": "num",
"x": 645,
"y": 225,
"wires": [
"a7f0880f05324738"
"id": "a7f0880f05324738",
"name": "Couch light 2 off?",
"version": 3,
"outputs": 2,
"halt_if": "off",
"value": "",
"property": "data",
"value": "",
"for": "0",
"forType": "num",
"x": 855,
"y": 225,
"wires": [
"1971be2af0682ca7"
"id": "1971be2af0682ca7",
"name": "Couch light 3 off?",
"version": 3,
"outputs": 2,
"halt_if": "off",
"value": "",
"property": "data",
"value": "",
"for": "0",
"forType": "num",
"x": 1065,
"y": 225,
"wires": [
"fd7eaf9abf479e0c"
"id": "fd7eaf9abf479e0c",
"name": "OFF: Couch light 3",
"version": 7,
"action": "light.turn_off",
"floorId": [],
"areaId": [],
"deviceId": [],
"entityId": [
"labelId": [],
"data": "",
"mergeContext": "",
"queue": "none",
"domain": "light",
"service": "turn_off",
"x": 1275,
"y": 225,
"wires": [
"id": "639ff6a4c30f7da4",
"version": 3,
"outputs": 2,
"halt_if": "off",
"value": "",
"property": "data",
"value": "",
"for": "0",
"forType": "num",
"x": 1065,
"y": 255,
"wires": [
"e6db7a222f12cdc5"
"id": "ea833815ed243b2c",
"version": 3,
"outputs": 2,
"halt_if": "off",
"value": "",
"property": "data",
"value": "",
"for": "0",
"forType": "num",
"x": 645,
"y": 255,
"wires": [
"38dd7c7b52f87b79"
"id": "38dd7c7b52f87b79",
"version": 3,
"outputs": 2,
"halt_if": "off",
"value": "",
"property": "data",
"value": "",
"for": "0",
"forType": "num",
"x": 855,
"y": 255,
"wires": [
"639ff6a4c30f7da4"
"id": "e6db7a222f12cdc5",
"name": "OFF: Couch light 1",
"version": 7,
"floorId": [],
"areaId": [],
"deviceId": [],
"entityId": [
"labelId": [],
"data": "",
"mergeContext": "",
"queue": "none",
"domain": "light",
"x": 1275,
"y": 255,
"wires": [
"id": "6bbfe8d5e2a8cb38",
"version": 3,
"outputs": 2,
"halt_if": "off",
"value": "",
"property": "data",
"value": "",
"for": "0",
"forType": "num",
"x": 855,
"y": 285,
"wires": [
"93424166989f36db"
"id": "278e5b9dfc8b1efa",
"version": 3,
"outputs": 2,
"halt_if": "off",
"value": "",
"property": "data",
"value": "",
"for": "0",
"forType": "num",
"x": 645,
"y": 285,
"wires": [
"6bbfe8d5e2a8cb38"
"id": "93424166989f36db",
"version": 3,
"outputs": 2,
"halt_if": "off",
"value": "",
"property": "data",
"value": "",
"for": "0",
"forType": "num",
"x": 1065,
"y": 285,
"wires": [
"cc2d7ff84e908f2b"
"id": "cc2d7ff84e908f2b",
"name": "OFF: Couch light 2",
"version": 7,
"floorId": [],
"areaId": [],
"deviceId": [],
"entityId": [
"labelId": [],
"data": "",
"mergeContext": "",
"queue": "none",
"domain": "light",
"x": 1275,
"y": 285,
"wires": [
"id": "4625e9cc31496995",
"type": "server-state-changed",
"name": "",
"version": 6,
"outputs": 1,
"exposeAsEntityConfig": "",
"entities": {
"entity": [
"light.living_room_lamp2"
"substring": [],
"regex": []
"outputInitially": false,
"stateType": "str",
"ifState": "",
"ifStateType": "str",
"ifStateOperator": "is",
"outputOnlyOnStateChange": true,
"for": "0",
"forType": "num",
"ignorePrevStateNull": false,
"ignorePrevStateUnknown": false,
"ignorePrevStateUnavailable": false,
"ignoreCurrentStateUnknown": false,
"ignoreCurrentStateUnavailable": false,
"value": "",
"property": "data",
"value": "",
"valueType": "eventData"
"property": "topic",
"value": "",
"valueType": "triggerId"
"x": 195,
"y": 195,
"wires": [
"9af23e0648886f8b"
"id": "9af23e0648886f8b",
"type": "trigger",
"name": "",
"op1": "",
"op2": "0",
"op1type": "nul",
"op2type": "str",
"duration": "15",
"extend": false,
"overrideDelay": false,
"units": "s",
"reset": "",
"bytopic": "all",
"topic": "topic",
"outputs": 1,
"x": 430,
"y": 195,
"wires": [
"278e5b9dfc8b1efa",
"ea833815ed243b2c",
"7b4cf5d1210eedb2",
"5c4360104a8f4f49",
"755e1ff0e41c8594",
"cf7c317535a9c090"
"id": "ab3e2c53.e3491",
"type": "server",
"name": "AvilaSmartHome",
"version": 5,
"addon": true,
"rejectUnauthorizedCerts": true,
"ha_boolean": "y|yes|true|on|home|open",
"connectionDelay": true,
"cacheJson": true,
"heartbeat": false,
"heartbeatInterval": 30,
"areaSelector": "friendlyName",
"deviceSelector": "friendlyName",
"entitySelector": "friendlyName",
"statusSeparator": "at: ",
"statusYear": "hidden",
"statusMonth": "short",
"statusDay": "numeric",
"statusHourCycle": "h23",
"statusTimeFormat": "h:m",
"enableGlobalContextStore": true
