Help me to automatically adjust brightness of my ambiental lights based on sun position
Hello everyone,
I find it quite difficult as I struggled a few hours a week ago, and also today I tried again for about 30 minutes, and I always encountered some errors.
I have led strips in all my plinths but in the night time the light is too bright if it’s turned on at 100%. In other areas like above the kitchen countertop or under the bar where the light is NOT directly visible, it’s ok to be at 100%, but in the plinths, is not ok.
For now I only have radar sensors in 3 rooms, but all the rooms will in the end have radar sensors so the lights will turn on automatically.
I also made a dashboard with a small button for every light strip, I tried today again to make an adjustable brightness based on sun position, the code evolved like this:
#v.1
      - type: vertical-stack
        cards:
          - type: custom:mushroom-chips-card
            alignment: center
            chips:
            - type: light
              entity: light.esp32_mos_x3_d_led_strip_d3_office
              content_info: none
              icon: mdi:laptop
#v2 than I added an tooltip like description for the button
              - type: light
                content_info: none
                icon: mdi:laptop
                card_mod:
                  style: |
                    ha-card:hover::after {
                      content: "Office";
                      position: absolute;
                      bottom: 110%; /* Apare deasupra butonului */
                      left: 50%;
                      transform: translateX(-50%);
                      background-color: rgba(0, 0, 0, 0.8);
                      color: white;
                      padding: 4px 8px;
                      border-radius: 4px;
                      font-size: 10px;
                      white-space: nowrap;
                      z-index: 100;
                      pointer-events: none;
#v3 than tried to turn it on at a certain level, and it worked
              - type: light
                entity: light.esp32_mos_x4_a_led_strip_a1_livingroom
                content_info: none
                icon: mdi:sofa
                hold_action:
                  action: more-info
                tap_action:
                  action: call-service
                  service: light.toggle
                    entity_id: light.esp32_mos_x4_a_led_strip_a1_livingroom
                    transition: 5
                    brightness_pct: 50
#v4 AND THE PROBLEM STARTED WHERN I TRIED TO USE AN HELPER NUMBER INSTEAD OF 50 as the brightness
                tap_action:
                    transition: 5
                    brightness_pct: >-
                      {{ states('input_number.leds_adaptive_brightness') | int
# or
                    brightness_pct: "{{ states('input_number.leds_adaptive_brightness') | int }}"
# AND THIS ERROR SHOWED UP
Failed to perform the action light/toggle. expected float for dictionary value @ data['brightness_pct']
This is my YAML automation to update the helper number every 15 minutes
alias: LEDs Adaptive Brightness Helper
description: Actualizează valoarea luminozității în funcție de soare
triggers:
  - minutes: /15
    trigger: time_pattern
  - event: sunrise
    trigger: sun
  - event: sunset
    trigger: sun
  - event: start
    trigger: homeassistant
actions:
  - target:
      entity_id: input_number.leds_adaptive_brightness
      value: |
        {% if is_state('sun.sun', 'above_horizon') %}
          100
        {% elif state_attr('sun.sun', 'elevation') > -18 %}
          50
        {% else %}
          30
        {% endif %}
    action: input_number.set_value
mode: single
The error is also displayed in the video bellow, for the first light button only, as I only tried to modify that one
So what is everyone using in this case, when we want the lights to turn on at a certain level based on day/night conditions?
I hoped there is a simple attribute I can attach to any automation (the one that turns on my lights when motion sensor detects motion) or to any button when I turn the light manually, but it seems I haven’t found the way to do it.
How to use HELPERS in the code of an light.toggle button ?
PS. I also tried to use the script inside the brightness_pct option inside the data, as in this topic , but it failed with the exact same error
Have you tried changing | int to | float like the error says?
I believe the card doesn’t support the use of Jinja2 templates. That’s why it’s complaining that the value for the following line is not a float because it cannot process the template.
I suggest you do the following:
  • Create a script that sets the light’s brightness_pct using your template.
  • Change the tap_action to execute the script.
Related
@ShadowFist I did tried and the error is the same:
That’s exactly what Gemini recommanded but I was sure is way to complicated for such a simple task :frowning:
So the problem is the mushroom button I used to turn on? Is there other similar, small button I can use, a different card?
But what about the automation, I’m allowed to use this line in an automation, will it work?
brightness_pct: “{{ states(‘input_number.leds_adaptive_brightness’) | int }}”
Yes because scripts and automations support Jinja2 templates.
None of Home Assistant’s standard cards support templates (except for the Markdown card). Some custom cards support Jinja2 templates but not all.
It’s a common solution for cards that don’t support templates.
