Help, my Home Assistant is going crazy
First of all I’m a rookie so correct me if I’m wrong. Home Assistant was all working fine until I installed AirCast. Suddenly I wasn’t able to reach my panel, after that I reinstalled hassio using etcher. But now my xaomi yeelights disappeared (usually they become visible without any configuration). My panel is only reachable using localhost:8123 but not using (ip-address):8123. In the hamburger menu I can’t find the ‘hassio’ tab where I usually can install GitHub packages. Who can help me fix this mess?
Did the IP address HA server change? How did you confirm?
Not uncommon.
Make sure you have the line
hassio:
In your config.yaml
