Help need with ZigBee
I have installed a Nortek HUSBZB-1. I am trying to get it setup so the following happens:
  1. Instead of /dev/ttUSB0 or /dev/ttyUSB1 it looks like /dev/ttyZWave or /dev/ttyZigBee
  2. The system see’s it but I am unable to pair an unpaired Hue Bulb
I’ll lake all the help I can get. I have tried to run the bellows command and it is not find it.
Okay was able to get passed the bellows issue by issuing this command:
sudo pip3 install update bellows
Still unable to pair my bulb and still working on reassign the name for the zwave and zigbee controller.
PS - I am a total linux noob but I am willing to learn and hack away.
If the device shows up as /dev/ttyZigbee then just add that path to your configuration.yaml under the zigbee: label and reboot. No need to rename the device.
It shows up as usb0 or usb1 but if you unplug it or reboot and it get discovered later it could be usb1 or USB2. I want a away to set it and forget. So no matter how it gets discovered it will always be usbZigBee.
The easiest way to set up a USB device so it always registers the same is using by-id
``ls /dev/serial/by-id`
should show you two devices. Those names will not change. I don’t have the same device so I can’t help you decide which device is which
