Home Assistant Community
Help NEEDED, Can't find the Syntax error (Not completely Solved)
#1
So, I’m getting the following error;
2019-02-09 21:20:37 WARNING (MainThread) [homeassistant.components.mqtt.sensor] configuration variable "json_attributes" is deprecated, replace with "json_attributes_topic"
So, I went thru the configuration of ALL my sensors, and did not find the “json_attributes” syntax being used. I also commented out, each sensor, one at a time, and restarted Hassio, then checked the log. But, the error never went away…
What am I missing???
I am including my “sensors.yaml” file, maybe someone will see something that I am missing.
#======================== Weather Sensor =====================
  - platform: darksky
    api_key: !secret darksky_api_key
    monitored_conditions:
      - nearest_storm_distance
      - temperature
      - dew_point
      - wind_speed
      - wind_bearing
      - humidity
      - pressure
      - visibility
      - precip_type
      - cloud_cover
      - hourly_summary
#      - moon_phase
  - platform: moon
  # - platform: mqtt
    # name: "Node RED"
    # state_topic: "checkin/nodered"
    # expire_after: 300
#============Multi Sensors - by BRUH Automations==============
  - platform: mqtt
    state_topic: "climate/li-room"
    name: "Livingroom Humidity"
    unit_of_measurement: "%"
    value_template: '{{ value_json.humidity | round(1) }}'
  - platform: mqtt
    unit_of_measurement: "LUX"
    value_template: '{{ value_json.ldr }}'
  - platform: mqtt
    value_template: '{{ value_json.motion }}'
  - platform: mqtt
    name: "Livingroom Temperature"
    unit_of_measurement: "F"
    value_template: '{{ value_json.temperature | round(1) }}'
  - platform: mqtt
    name: "Livingroom Real Feel"
    value_template: '{{ value_json.heatIndex | round(1) }}'
  - platform: mqtt
    name: "Livingroom WiFi RSSI"
    unit_of_measurement: "db"
    value_template: '{{ value_json.signal_strength }}'
  - platform: mqtt
    state_topic: "climate/cellar"
    name: "Cellar Humidity"
  - platform: mqtt
    ##This sensor is not calibrated to actual LUX. Rather, this a map of the input voltage ranging from 0 - 1023.
  - platform: mqtt
  - platform: mqtt
    name: "Cellar Temperature"
  - platform: mqtt
    name: "Cellar Real Feel"
  - platform: mqtt
    name: "Cellar WiFi RSSI"
  - platform: mqtt
    state_topic: "climate/mb-room"
    name: "Bedroom Humidity"
  - platform: mqtt
  - platform: mqtt
  - platform: mqtt
    name: "Bedroom Temperature"
  - platform: mqtt
    name: "Bedroom Real Feel"
  - platform: mqtt
    name: "Bedroom WiFi RSSI"
  - platform: mqtt
    state_topic: "climate/ki-room"
    name: "Kitchen Humidity"
  - platform: mqtt
    ##This sensor is not calibrated to actual LUX. Rather, mapped the input voltage to ranging from 0 - 1023.
  - platform: mqtt
  - platform: mqtt
    name: "Kitchen Temperature"
  - platform: mqtt
    name: "Kitchen Real Feel"
  - platform: mqtt
    name: "Kitchen WiFi RSSI"
#====================== System Sensors =======================
  - platform: uptime
    unit_of_measurement: hours
#  - platform: speedtest
#    minute:
#      - 0
#      - 15
#      - 30
#      - 45
#    monitored_conditions:
#      - download
#      - upload
#      - ping
  - platform: systemmonitor
    resources:
      - type: disk_free
        arg: /home
      - type: swap_free
      - type: processor_use
      - type: last_boot
#      - type: disk_use_percent
#        arg: /home
#      - type: disk_use
#        arg: /home
#      - type: memory_use_percent
#      - type: memory_free
#      - type: swap_use_percent
#      - type: swap_use
#      - type: network_in
#        arg: eth0
#      - type: network_out
#        arg: eth0
#      - type: packets_in
#        arg: eth0
#      - type: packets_out
#        arg: eth0
#      - type: ipv4_address
#        arg: eth0
#      - type: ipv6_address
#        arg: eth0
#      - type: last_boot
#      - type: process
#        arg: octave-cli
#      - type: load_15m
#  - platform: cpuspeed
#    name: "CPU Speed = "
# SSL Certificate, days til expiration
  - platform: cert_expiry
    host: !secret ha_cert_exp
    port: 443
    scan_interval: 3600
  - platform: time_date
    display_options:
      - 'time'
      - 'date'
      - 'date_time'
#================= POW Sensors - by DigiBlur =================
  - platform: mqtt
    state_topic: "stat/snf-washer/POWER"
    icon: mdi:washing-machine
  - platform: mqtt
    state_topic: "tele/snf-washer/SENSOR"
    value_template: "{{value_json['ENERGY'].Power }}"
    qos: 2
    unit_of_measurement : "W"
    icon: mdi:flash-circle
    availability_topic: "tele/snf-washer/LWT"
    payload_available: "Online"
    payload_not_available: "Offline"
  - platform: mqtt
    value_template: "{{value_json['ENERGY'].Voltage }}"
    qos: 2
    unit_of_measurement : "V"
  - platform: mqtt
    value_template: "{{value_json['ENERGY'].Current }}"
    qos: 2
    unit_of_measurement : "A"
  - platform: mqtt
    name: "Washer Energy Today"
    value_template: "{{value_json['ENERGY'].Today }}"
    qos: 2
    unit_of_measurement : "kWh"
  - platform: mqtt
    name: "Washer Energy Yesterday"
    value_template: "{{value_json['ENERGY'].Yesterday }}"
    qos: 2
  - platform: mqtt
    state_topic: "tele/snf-washer/STATE"
    value_template: "{{value_json['Wifi'].RSSI }}"
    qos: 1
  - platform: mqtt
    state_topic: "stat/snf-refrig/POWER"
    icon: mdi:fridge-outline
  - platform: mqtt
    state_topic: "tele/snf-refrig/SENSOR"
    qos: 2
    availability_topic: "tele/snf-refrig/LWT"
  - platform: mqtt
    qos: 2
  - platform: mqtt
    qos: 2
  - platform: mqtt
    name: "Refrigerator Energy Today"
    qos: 2
  - platform: mqtt
    name: "Refrigerator Energy Yesterday"
    qos: 2
  - platform: mqtt
    state_topic: "tele/snf-refrig/STATE"
    qos: 1
  - platform: mqtt
    name: "SNF Spare 1 State"
    state_topic: "stat/snf-spare1/POWER"
  - platform: mqtt
    name: "SNF Spare 1 Watts"
    state_topic: "tele/snf-spare1/SENSOR"
    qos: 2
    availability_topic: "tele/snf-spare1/LWT"
  - platform: mqtt
    name: "SNF Spare 1 Voltage"
    qos: 2
  - platform: mqtt
    name: "SNF Spare 1 Amps"
    qos: 2
  - platform: mqtt
    name: "SNF Spare 1 Energy Today"
    qos: 2
  - platform: mqtt
    name: "SNF Spare 1 Energy Yesterday"
    qos: 2
  - platform: mqtt
    state_topic: "tele/snf-spare1/STATE"
    name: "SNF Spare 1 Signal"
    qos: 1
  - platform: mqtt
    name: "SNF Spare 2 State"
    state_topic: "stat/snf-spare2/POWER"
  - platform: mqtt
    name: "SNF Spare 2 Watts"
    state_topic: "tele/snf-spare2/SENSOR"
    qos: 2
    availability_topic: "tele/snf-spare2/LWT"
  - platform: mqtt
    name: "SNF Spare 2 Voltage"
    qos: 2
  - platform: mqtt
    name: "SNF Spare 2 Amps"
    qos: 2
  - platform: mqtt
    name: "SNF Spare 2 Energy Today"
    qos: 2
  - platform: mqtt
    name: "SNF Spare 2 Energy Yesterday"
    qos: 2
  - platform: mqtt
    state_topic: "tele/snf-spare2/STATE"
    name: "SNF Spare 2 Signal"
    qos: 1
  - platform: mqtt
    state_topic: "stat/led_pole_1/locator"
#====================== Stocks to Watch=======================
#=======================XYSTJS1QZXGHIMV1.=====================
  - platform: alpha_vantage
    api_key: !secret alpha_vantage_key
    symbols:
      - symbol: HPQ
      - symbol: HPE
        name: Hewlett-Packard Enterprise Co.
      - symbol: MRMD
      # - symbol: ARNA
        # name: Arena Pharmaceuticals Inc.
      # - symbol: CARA
        # name: Cara Therapeutics Inc.
      # - symbol: CRBP
        # name: Corbus Pharmaceuticals Holdings Inc.
      # - symbol: CRON
        # name: Cronos Group Inc.
      # - symbol: GWPH
        # name: GW Pharmaceuticals Plc.
      # - symbol: INSY
        # name: Insys Therapeutics Inc.
      # - symbol: NTEC
        # name: Intec Pharma Ltd.
      # - symbol: MBII
        # name: Marrone Bio Innovations, Inc.
      # - symbol: PMD
        # name: Psychemedics Corporation
      # - symbol: TRPX
        # name: Therapix Biosciences Ltd.
      # - symbol: TLRY
        # name: Tilray Inc.
      # - symbol: ZYNE
        # name: Zynerba Pharmaceuticals Inc.
#2
Do you have any custom components that might be using it?
#3
Not sure, can you give an example of a Custom component?
#4
Do you have anything in /config/custom_components?
#5
I have a Binary sensor in my Configuration.yaml, that looks likee the following;
binary_sensor:
  platform: mqtt
  state_topic: "homeassistant/binary_sensor/CarPresence/state"
#6
Nope that’s a built in component (binary_sensor).
#7
NO, to the /config/custom_components…
#8
I noticed the same thing. I think I’ve isolated it to the “battery alert” package I’ve been running flawlessly for close to a year now but the recent HA version upgrades are starting to annoy it.
Have you installed that package?
I am running HA Switch Plate, and that uses a package. I will check that out…
#10
Found the Sensor that is causing the problem, it’s in the HA Switch Plate Package, specifically, in the “hasp_plate01_00_components.yaml” file
#11
What was the error. Others might learn from it.
#12
@stevemann
^^^^^^^^^^^^^^ Read the opening topic. ^^^^^^^^^^^^^^
#13
Again: What was the error. Others might learn from it.
The opening topic had your sensors.yaml file and nowhere in it was “hasp_plate01_00_components” mentioned. So, YOU found the offending sensor. Fine. How did you figure out that it was in a yaml file that you hadn’t mentioned in the OP and isn’t included in the sensors file?
#14
Sorry Not an error, it was a WARNING.
Found the Sensor that is causing the problem, it’s in the HA Switch Plate Package, specifically, in the “hasp_plate01_00_components.yaml” file, line# 47-59. I included the code below.
  - platform: mqtt
    state_topic: "hasp/plate02/sensor"
    value_template: '{{ value_json.status }}'
    json_attributes:
      - espVersion
      - updateESPAvailable
      - lcdVersion
      - updateLcdAvailable
      - espUptime
      - signalStrength
      - haspIP
And I still have not found any info, that clearly explains how to fix it. I know it is this sensor, that causing the warning, because, when I comment out the “packages: !include_dir_named packages” line in my configuration.yaml file. The warning goes away.
And, I don’t think this sensor can be discovered.
#15
json_attributes is deprecated now, and should be replaced by implementing json_attributes_topic inplace of it. This is mentioned in the component documentation.
Since in your case, this warning is being generated by the HA switchplate custom package, you can either attempt to modify it yourself, or raise a bug with the HA switchplate development team, wait for a fix to be released, then upgrade.
If you want to file a bug, this is the link to their repo I believe, which has an issues section where you can let them know that some of the code being used includes deprecated functions.
#16
@Silicon_Avatar Aderusha added an update 3 days ago, but apparently, not for this issue. ;-(
And as for the component documentation, it does not dumb it down, enough for me. Everything I tried form that document, has not worked for me…
#17
list an example of the things you’ve tried…
#19
change it to this, obviously changing topic to match your plate name(plate02)
  - platform: mqtt
    state_topic: "hasp/test_plate/sensor"
    json_attributes_topic: "hasp/test_plate/sensor"
HA SwitchPlate - DIY LCD Touchscreen wall switch replacement
