If you did get the Spotify component working, then there should be a notification asking you to authorize Spotify with Home Assistant. After authorization, it looks like nothing happens but the Spotify media player should show up as an entity. This won’t happen if you already have token stored in the file “.spotify-token-cache”.
You can try deleting the cached token (called “.spotify-token-cache”) in your \config directory, reboot and try again.
And you’re sure you put the Spotify config in the media player section of configuration.yaml?
Have you tried validating the config in Home Assistant settings and see if any error messages pop up? And you’ve restarted Home Assistant from the Settings section as well? Home Assistant doesn’t actually restart (even if you click the Restart button) if there are errors in the configuration.yaml.
Sorry to assume but it really feels like a user error. There would be error logs at a minimum if ithe entry in configuration.yaml was correct.
Hello siytek, i followed your tutorial over here on installing hassio in ubuntu. I finally made it but why can’t i find home assistant container on my docker?
Hey @falithurrahman thanks for checking out my tutorial! I did not include Portainer in the tutorial as it is available in the add-on store, so you might be better just installing the add-on as it should work out of the box.
