I have summed up the power from 3 sensors, and it gives me the correct value I want. But I assume that this is just an integer. I want to have this value recognised as WATTS. A Utility Meter just increments. I just want a Watts figure every minute or whatever - and whatever that figure might be
Thanks all for the responses yesterday. Indeed @koying the SUM is in Watts as it is a combination of several Watts sensors.
I think the issue actually appears to be the Power Flow Card which doesn’t appear to recognise the Summed item as valid. I then confused it with another which I created for a different place on that card.
