Hi
If you are using HomeKit Controller integration and covers/blinds/shutters, we need your help.
To improve the HomeKit Controller integration with tilt functionality, the DevTeam needs your support.
A better understanding is needed what different brands of cover/blinds/shutter motors are reporting in the HomeKit Controller for the attribute current_tilt_position
To do so, go to Dev Tools → States and take note of the current_tilt_position
when tilt of your covers is open, and when closed.
Homekit is using degrees from -90° to +90° and not percent %, so a value cannot be 100. The latter is likely to be a % value from another integration than HomeKit Controller.
If you are using more than one integration to control your covers, make sure pick the correct entity.
Template and example from me:
Motor-brand: Somfy
Motor-model: Oximo 50 io
Value of tilt open: -90
Value of tilt closed: 0
Thanks a lot for your contribution
