The problem is that I have some trackers setup in HA whom I don’t want to be part of this automation. I have set up a parents group, with just me and my wife, so would this work?
- entity_id: group.parents
platform: state
to: not_home
Groups certainly tidy things up a little and I like the idea of being able to have different groups. In this instance, it would be simple to change from parent, to family etc.
I’m still learning yaml but learn a bit extra every day and today I have learnt loads thanks to you. Very much appreciated.
Thanks for the heads-up. I will look at my configuration this afternoon and add and entry-id - no doubt I’ll break it and will back on here asking what I did wrong
Thanks to all the help here, the thermostat is now working very well and I have a warmer house when it is required, but likely spending less, as it’s not on when no one is home.
I’ve discovered that I can turn the heating on using Alexa, because I have hue emulation enabled in Tasmota; however, the status is not reflected on the thermostat card in Lovelace UI i,e, I say ‘Alexa, turn on heating’, it comes on but the thermostat card shows as it being off. Is this something I can fix? Here’s the relevant pieces of yaml. “Lounge Heater” is the boiler switch controlled by climate and is is also the switch that Alexa is operating. I think Alexa reactions to ‘turn on heating’ as heating is the friendly name set in Tasmota
