Hi there.
I am by no means a programmer of any kind, have never been taught, and what I know about programming is self-taught.
I am having a problem with the new “if, then” condition in automation. in particular the numeric state condition. What I am trying to achieve is that when home assistant boots up, (let’s say after a power failure,) then if the office lamp is on at below 6% then the office light switch must turn on. Yes, the office lamp is on so that I can choose the brightness attribute. Can someone help me with this automation or point me in the right direction. For whatever reason, the numeric state does not see the brightness values. Please bear in mind that I don’t know code/coding etc…
The brightness attribute’s value ranges from 0 to 255. If you want 6% then six percent of 255 is approximately 15. That’s the value you would use for the below option. You are currently using 6 which represents approximately 2.4% brightness level.
In addition, if the automation fails to behave the way you expect, check its trace to understand why.
