Help needed with esp32 touchpad
I’m using a esp32-s3-devkitc-1-n32r8 with esphome version 2024.12.4.
Here is my yaml file :slight_smile:
esphome:
  platformio_options:
    build_flags:
      -DBOARD_HAS_PSRAM
      -mfix-esp32-psram-cache-issue
    board_build.arduino.memory_type: opi_opi
    board_build.f_flash: 80000000L
    board_build.flash_mode: qio
esp32:
  board: esp32-s3-devkitc-1
  framework:
    type: esp-idf
  flash_size: 32MB
# Working!  Don't change a thing
# Enable logging
logger:
# Enable Home Assistant API
api:
  password: ""
ota:
  - platform: esphome
    password: ""
wifi:
  ssid: "fakeWiFi"
  password: "runnyGreenEggs"
  ap:
    ssid: "S3Devkit Fallback Hotspot"
    password: "WPT9Z87bsEhl"
captive_portal:
light:
  - platform: esp32_rmt_led_strip
    rgb_order: GRB
    pin: GPIO38
    num_leds: 1
    rmt_channel: 0
    chipset: sk6812
esp32_touch:
  setup_mode: false
binary_sensor:
#  - platform: gpio
#    name: "Boot Button"
#    pin:
#      number: 0
#      inverted: true
#      mode:
#        pullup: true
#  - platform: esp32_touch
#    name: "Left Touch"
#    id: esp32_touch_left
#    pin: GPIO02
#    threshold: 0
    pin: GPIO10
    threshold: 0
    name: "Raw touch right"
    lambda: |-
        return id(esp32_touch_right).get_value();
    update_interval: 3s
The value is way to high (320000) and never changes.
I have tried several different pins and both esp-idf and arduino frameworks.
Thanks for any ideas
