Hi
I made an automation that monitors the changes of an iPhone GPS tracker to calculate the speed. That works, most of the times. Sporadically I get a template error that ‘max’ can’t compare str with float.
I’m staring blind I guess. Who understands how this error can be possible?!
I think I nailed down the error coming from `max’ in my automation (trigger by the iphone gps tracker):
- variables:
speed: |
{% set dm = (distance(trigger.to_state, trigger.from_state) | float(0)) * 1000.0 %}
{% set dt = (as_datetime(trigger.to_state.last_updated) - as_datetime(trigger.from_state.last_updated)).total_seconds() | float(0) %}
{{ (dm / <b>max(1.0,dt)</b>) | float(0) | round(1) }}
Please help
The full exception
Logger: homeassistant Source: helpers/template.py:645 First occurred: 12:58:48 (1 occurrences) Last logged: 12:58:48Error doing job: Task exception was never retrieved (None)
File “/usr/src/homeassistant/homeassistant/helpers/template.py”, line 643, in async_render
render_result = _render_with_context(self.template, compiled, **kwargs)
File “/usr/src/homeassistant/homeassistant/helpers/template.py”, line 2756, in _render_with_context
return template.render(**kwargs)
File “/usr/local/lib/python3.13/site-packages/jinja2/environment.py”, line 1295, in render
self.environment.handle_exception()
File “/usr/local/lib/python3.13/site-packages/jinja2/environment.py”, line 942, in handle_exception
raise rewrite_traceback_stack(source=source)
File “”, line 2, in top-level template code
File “/usr/local/lib/python3.13/site-packages/jinja2/sandbox.py”, line 401, in call
return __context.call(__obj, *args, **kwargs)
File “/usr/src/homeassistant/homeassistant/helpers/template.py”, line 2268, in wrapper
return builtin_filter(environment, args, **kwargs)
File “/usr/local/lib/python3.13/site-packages/jinja2/filters.py”, line 543, in do_max
return _min_or_max(environment, value, max, case_sensitive, attribute)
File “/usr/local/lib/python3.13/site-packages/jinja2/filters.py”, line 503, in _min_or_max
return func(chain([first], it), key=key_func)
TypeError: ‘>’ not supported between instances of ‘str’ and ‘float’The above exception was the direct cause of the following exception:
File “/usr/src/homeassistant/homeassistant/helpers/trigger.py”, line 278, in async_with_vars
run_variables.update(trigger_variables.async_render(hass, run_variables))
File “/usr/src/homeassistant/homeassistant/helpers/script_variables.py”, line 57, in async_render
rendered_variables[key] = template.render_complex(
value, rendered_variables, limited
File “/usr/src/homeassistant/homeassistant/helpers/template.py”, line 266, in render_complex
return value.async_render(variables, limited=limited, parse_result=parse_result)
File “/usr/src/homeassistant/homeassistant/helpers/template.py”, line 645, in async_render
raise TemplateError(err) from err
homeassistant.exceptions.TemplateError: TypeError: ‘>’ not supported between instances of ‘str’ and ‘float’
Update:
I moved the variables from the trigger, to the action part, and that probably seems to solve it, Need to monitor it for a while.
