Help negative/positive value template from Grid sensor Import and export
Hi everyone, I need help because I don’t know how to do it, I need to create a sensor that shows me a negative value if I’m taking energy from the GRid and a positive value if I’m feeding it into the grid.
In home asistan I have two separate sensors one for import and the other for export
can you help me?
It’d help if you gave us details of the sensors, otherwise we need to make them up and then you need to convert our made-up sensors back to your real ones.
Create a template sensor in the UI (under Helpers) with this as the state template:
{{ states('sensor.export')|float(0) - states('sensor.import')|float(0) }}
That simply subtracts import from export. If that’s not what you need, be clear on what your two sensors provide.
Thanks a lot, Troon! I had the same problem and this works perfectly.
