Help on input_number slider needed: set a switch to off after x minutes from slider value
already searched the forums and also found some input, but still have issues to get it running.
Running latest Hass.io and lovelayce (yaml mode).
What i want to do: my water irrigation starts by either a) a switch turned to on or b) if in automation mode, at a specific time. Works so far.
What i want to achieve is to set the switch to off again after a specified time using a slider.
Seems to be a problem in the automation, if i uncomment it the code check runs.
Definition of slider and time (from within a package):
input_datetime:
  bewaesserung_on:
    has_date: false
    has_time: true
input_boolean:
  auto_bewaesserung:
    name: Automatik (täglich)
    icon: mdi:auto-fix
input_number:
  bewaesserung_dauer:
    min: 10
    max: 60
    step: 10
The automation:
automation:
### Gartenbewaesserung starten
- alias: bewaesserung_start
      value_template: '{{ states.sensor.time.state == (states.input_datetime.bewaesserung_on.attributes.timestamp | int | timestamp_custom("%H:%M", False)) }}'
  condition:
    condition: state
    entity_id: input_boolean.auto_bewaesserung
    state: 'on'
    service: homeassistant.turn_on
    entity_id:
      - switch.switch_wasser
### Bewaesserung stoppen
- alias: bewaesserung_stoppen
    platform: state
    entity_id: switch.switch_wasser
    to: 'on'
    - delay: '00:{{ states.input_number.bewaesserung_dauer.state | int }}:00'
    - service: homeassistant.turn_off
    - entity_id: switch.switch_wasser
Thanks for pointing me into the right direction.
/ Ralf
to
    - service: switch.turn_off
Just a few thoughts to maybe simplify things a bit.
The trigger in your first automation could be:
      value_template: "{{ states('sensor.time') ~ ':00' == states('input_datetime.bewaesserung_on') }}"
And the action can be:
Delays can also take a number of seconds, so it could be:
    - delay: "{{states('input_number.bewaesserung_dauer')|float * 60 }}"
But the reason the second automation wasn’t working is there should not be a dash before entity_id in the action.
Thanks very much for the hint!
One dash too much can cause trouble… :wink:
/ Ralf
