hi ,i’m trying to use a local usb speakerphone directly connected to my home assistant server. I have installed the OPENWAKEWORD addon , uninstall ,reinstall and it doesnt show up in discovered…, and i’ve looked online , and i dont see the 3 dot in assistant configuration window to choose local wake word. Am i missing something ? if someone would help it be nice .
Hi
In Wyoming Integration click on ADD SERVICE , host : 127.0.0.1(localhost IP) and port: 10400 (default one)
hi, thanks fo the help but i’m getting a failed to connect when i do that, both with local host ip and with local ip .
You can try changing port in openwakeword addon configuration ( 10450 ?) , and retry with host : 127.0.0.1 , port: 10450
I use microwakeword addon with assist-microphone, less choice but very more accurate with OK Nabu
thanks its worked
i will looked into microwakeword, thanks for the heads up !
Don’t use same port for microwakeword addon
