Hi there.
Thanks in advance.
I’ve been following the YouTube ‘Domotica Solar’ guide on automating the heaters and boiler at home, but I have a problem.
I need to add a 5-minute delay between the thermostat change to “heating” and the boiler starts, because I need the valve to fully open, to allow water circulation.
This is the action I’m trying to change:
service_template: >
{% if is_state_attr('climate.calefaccion_gamer','hvac_action','heating') or
is_state_attr('climate.calefaccion_hab_1','hvac_action','heating') or
is_state_attr('climate.calefaccion_hab_2','hvac_action','heating') or
is_state_attr('climate.calefaccion_hab_ppal','hvac_action','heating') %}
switch.turn_on
{% else %}
switch.turn_off
{% endif %}
entity_id: switch.caldera
I must add a delay after the template is considered “true” and the switch is turned on.
Any ideas?
Thanks for the support!!!
Post the whole automation… there are a few ways to approach this, but they aren’t all going to be appropriate in every circumstance.
Thanks for the quick answer. In any case, after posting I got inspired… Now its working fine:
alias: Encender caldera a demanda
description: ""
triggers:
- trigger: state
entity_id:
- climate.calefaccion_gamer
- climate.calefaccion_hab_1
- climate.calefaccion_hab_2
- climate.calefaccion_hab_ppal
- input_boolean.calefaccion_general
attribute: hvac_action
conditions:
- condition: state
entity_id: input_boolean.calefaccion_general
state: "on"
actions:
- if:
- condition: template
value_template: >-
{{ is_state_attr('climate.calefaccion_gamer','hvac_action','heating')
or
is_state_attr('climate.calefaccion_hab_ppal','hvac_action','heating') }}
then:
- delay:
hours: 0
minutes: 5
seconds: 0
milliseconds: 0
- action: switch.turn_on
metadata: {}
data: {}
else:
- action: switch.turn_off
metadata: {}
data: {}
mode: single
If you have any suggestions to improve, they are more than welcome!
Another option would be to set up an template binary sensor with a delay_on
like:
template:
- binary_sensor:
- name: Demanda Calefacción
state: |
{{ 'heating' in ["climate.calefaccion_gamer","climate.calefaccion_hab_1",
"climate.calefaccion_hab_2","climate.calefaccion_hab_ppal"]
| map('state_attr', 'hvac_action') | list }}
delay_on: "00:05:00"
Then your automation would be:
description: ""
triggers:
- trigger: state
entity_id: binary_sensor.demanda_calefaccion
to:
- "on"
- "off"
conditions:
- condition: state
state: "on"
actions:
- action: switch.turn_{{ trigger.to_state.state }}
metadata: {}
data: {}
mode: single
