Help required for switching on heater when temperature drops between certain
Hoping someone can help a noob who’s new to HA.
For context, I have cheap electricity between 23:30 and 05:30 every day.
I want to create an automation that switches on my electric heater when the temperature drops below 19C only between 23:30 and 05:30. It must switch off when the temperature reaches 21C.
The temperature sensor and the smart switch to control the electric heater are both connected to HA.
Can someone help me?
Create a generic thermostat with the switch and temperature sensor.
Set the climate entity how you want.
Then add this automation:
description: ""
mode: single
triggers:
  - trigger: time
    at: "23:30:00"
  - trigger: time
    at: "05:30:00"
conditions: []
actions:
- action: "climate.turn_{{ trigger.id }}"
  metadata: {}
  data: {}
    entity_id:
      - climate.electric_heater
Thanks. I’ve given that a go. Much appreciated
