I have a rest sensor that returns the following json string.
{“result”:{“stats”:[{“balance”:“0.00002685”,“rejected_speed”:“0”,“algo”:5,“accepted_speed”:“0”},{“balance”:“0.00016852”,“rejected_speed”:“0”,“algo”:7,“accepted_speed”:“0”},{“balance”:“0.00004954”,“rejected_speed”:“0”,“algo”:14,“accepted_speed”:“0”},{“balance”:“0.0000373”,“rejected_speed”:“0”,“algo”:20,“accepted_speed”:“0”},{“balance”:“0.00000381”,“rejected_speed”:“0”,“algo”:21,“accepted_speed”:“0”},{“balance”:“0.00082938”,“rejected_speed”:“0”,“algo”:22,“accepted_speed”:“0.000004”},{“balance”:“0.00013585”,“rejected_speed”:“0”,“algo”:24,“accepted_speed”:“0.00000046”}],“payments”:[{“amount”:“0.00144643”,“fee”:“0.00002952”,“TXID”:"",“time”:“2018-01-25 11:07:55”},{“amount”:“0.00116031”,“fee”:“0.00002368”,“TXID”:"",“time”:“2018-01-23 10:43:39”}],“addr”:“22e5rZiEHzLcMUCVAcMAbSigUgA6981Kqg”},“method”:“stats.provider”}
I am using the following value template statement to capture the balance value in the array:
value_template: '{{ value_json.result.stats[0]["balance"] }}'
This will only capture the first value.
What I am looking to do is capture all of the balance values and sum them together to produce the sensor value. Is this possible?
