Help setting a tuya smart light + fan
Hi Folks,
I am having some trouble configuring a tuya smart ceiling lamp + fan. ANd I would really appreciate some support (or where to find the info to find the solution myself).
I have a smart ceiling lamp + fan via tuya. I got the keys, device ID and some script with the DPs. (or at least i think so). The device has a static IP (automatically assigned by the router via mac adress) and i have remove it from the tuya app (I think you can only control the lights from 1 device/system).
My issue:
I simply cant control anything from home assitant; I assume that I put the wrong DP in the configuration.
  "result": {
    "properties": [
        "code": "switch_led",
        "custom_name": "",
        "dp_id": 20,
        "time": 1744961322998,
        "type": "bool",
        "value": false
        "code": "work_mode",
        "custom_name": "",
        "dp_id": 21,
        "type": "enum",
        "value": "white"
        "code": "bright_value",
        "custom_name": "",
        "dp_id": 22,
        "type": "value",
        "value": 10
        "code": "temp_value",
        "custom_name": "",
        "dp_id": 23,
        "type": "value",
        "value": 0
        "code": "control_data",
        "custom_name": "",
        "dp_id": 28,
        "type": "string",
        "value": ""
        "code": "power_memory",
        "custom_name": "",
        "dp_id": 33,
        "type": "raw"
        "code": "do_not_disturb",
        "custom_name": "",
        "dp_id": 34,
        "type": "bool",
        "value": false
        "code": "fan_switch",
        "custom_name": "",
        "dp_id": 101,
        "type": "bool",
        "value": false
        "code": "fan_mode",
        "custom_name": "",
        "dp_id": 102,
        "type": "enum",
        "value": "fresh"
        "code": "fan_beep1",
        "custom_name": "",
        "dp_id": 103,
        "type": "bool",
        "value": false
        "code": "fan_speed",
        "custom_name": "",
        "dp_id": 104,
        "type": "value",
        "value": 1
        "code": "fan_direction",
        "custom_name": "",
        "dp_id": 105,
        "type": "enum",
        "value": "forward"
        "code": "white_switch",
        "custom_name": "",
        "dp_id": 107,
        "type": "bool",
        "value": false
        "code": "white_scene1",
        "custom_name": "",
        "dp_id": 109,
        "type": "raw"
        "code": "countdown1",
        "custom_name": "",
        "dp_id": 112,
        "type": "value",
        "value": 0
        "code": "switch_gradient1",
        "custom_name": "",
        "dp_id": 113,
        "type": "raw"
        "code": "main_switch",
        "custom_name": "",
        "dp_id": 119,
        "type": "bool",
        "value": false
        "code": "nightlight_switch",
        "custom_name": "",
        "dp_id": 143,
        "type": "bool",
        "value": false
  "success": true,
  "t": 1744961511236,
  "tid": "31ac4a721c2711f0942fe62c0c16c951"
