I’m new to using homeassistant anywhere. I have am having issues in my automation, I’d like to know that my mqtt is setup properly, in case I might have missed something.
Running
hass --script check_config
this, doesn’t show any errors.
What I’ve done is installed library paho-mqtt and this is the python script that I run with nohup via ssh.
import RPi.GPIO as GPIO
import picamera
import paho.mqtt.client as mqtt
import paho.mqtt.publish as publish
import argparse
import signal
import sys
import time
import logging
import datetime
### camera
camera = picamera.PiCamera()
camera.vflip=True
#mqtt
broker = '192.168.0.103'
topic = 'dev/test'
mqttQos = 0
mqttRetained = False
# setup for taking input from switch
GPIO.setmode(GPIO.BCM)
GPIO.setup(17, GPIO.IN, pull_up_down = GPIO.PUD_UP)
prev_input = 0
def on_connect(client, userdata, flags, rc):
print("Connected with result code "+str(rc))
client.subscribe(topic)
# The callback for when a PUBLISH message is received from the server.
def on_message(client, userdata, msg):
payload = str(msg.payload.decode('ascii')) # decode the binary string
print(msg.topic + " " + payload)
process_trigger(payload)
client = mqtt.Client()
client.on_connect = on_connect # call these on connect and on message
client.on_message = on_message
client.username_pw_set(username='pi',password='user_pass') # need this
client.connect(broker)
client.loop_start() # run in background and free up main thread
def post_image():
print('Taking photo')
camera.capture('image.jpg')
file_name = 'image_' + str(datetime.datetime.now()) + '.jpg'
camera.capture(file_name) # time-stamped image # create an object for this file and then pass the object here
with open('image.jpg', "rb") as imageFile:
myFile = imageFile.read()
data = bytearray(myFile)
client.publish('dev/camera', data, mqttQos, mqttRetained) #
client.publish('dev/test', 'Capture!')
print(file_name + 'image published')
while True:
input = GPIO.input(17)
if ((not prev_input) and input):
post_image()
time.sleep(2)
prev_input = input
time.sleep(0.2)
and this is my configuration.yaml.
notify:
- platform: telegram
chat_id: xxxxxxxx
telegram_bot:
- platform: polling
api_key: yyyyyyyyyyy:some_thing_somet_hing_here.
allowed_chat_ids:
- xxxxxxxxxxx
mqtt:
#this is empty here
automation:
- alias: Doorbell_pressed_automation
platform: mqtt
topic: dev/test
payload: 'Capture!'
- service: automation.turn_off
entity_id: automation.doorbell_pressed_automation
- service: script.turn_on
entity_id: script.doorbell_pressed_script
- delay: "00:00:5"
- service: automation.turn_on
script:
doorbell_pressed_script:
alias: 'notify me'
sequence:
- service: notify.telegram
title: Home Assistant Notification
message: --Doorbell Pressed--
photo:
- url: http://192.168.0.103/images/image.jpg
caption: Doorbell View
dev_publish_on_script:
sequence:
- service: mqtt.publish
data: {"topic":"dev/test", "payload":"ON"}
test_telegram:
alias: 'test_telegram'
sequence:
title: TEST Message
message: 'This is a test!'
photo:
